Body lift for 2002 5 lug
Discussion in '5 Lug' started by Ali3n898, Nov 27, 2014.
  1. Nov 27, 2014 at 1:20 PM
    Ali3n898
    Ali3n898 [OP] Well-Known Member
    Alex
    Houston, Tx
    None just yet, just a few cosmetic changes
    Anybody selling or know where I can get a body lift kit for a 2002 tacoma 5 lug? No more than 2 inch body lift.
  2. Nov 27, 2014 at 1:39 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Why would you want to lift a 5 lug?
  3. Nov 27, 2014 at 1:50 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Because he wants to??
  4. Nov 27, 2014 at 1:57 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    I'd go with a spindle lift and leaves over a BL.. but I found several just by googling it when I had a 5lug
  5. Nov 27, 2014 at 1:59 PM
    Ali3n898
    Alex
    Houston, Tx
    Thanks delta, my exact reasoning. I have a spindle, v6 coils and a spacer already. I guess my real question is, do the body lift kits differ? I've seen some but they don't specify if they are meant for 5 lugs, and whether or not they come with the steering column extension. Do I need a specific one? Or will the body lift be same as a 2wd v6?
  6. Nov 27, 2014 at 2:02 PM
    Ali3n898
    Alex
    Houston, Tx
    ImageUploadedByTapatalk1417125744.176936.jpg that's the truck so far
  7. Nov 27, 2014 at 2:03 PM
    Ali3n898
    Alex
    Houston, Tx
  8. Nov 27, 2014 at 2:05 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    :jerkoff:
  9. Nov 27, 2014 at 3:02 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Do you ever sleep?
  10. Nov 27, 2014 at 7:49 PM
    T4RFTMFW
    Sorry, I was taking a nap. No.
  11. Nov 27, 2014 at 8:35 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    :rolleyes: Thought not. Especially with over 6k posts in a few months you can't have time to sleep!
  12. Nov 27, 2014 at 8:38 PM
    T4RFTMFW
  13. Nov 27, 2014 at 9:48 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    What size spacer? Do you have front and rear spacers already?
  14. Nov 28, 2014 at 11:47 PM
    Ali3n898
    Alex
    Houston, Tx
    I have a 1 inch coil spacer up front, 3 inch spindle lift and v6 coils. Nothing done to rear
  15. Nov 29, 2014 at 11:55 AM
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Lol sorry i know I wrote 5 lug but in my mind I was thinking 6. Didn't mean to a " :jerkoff: "
  16. Dec 16, 2014 at 3:09 PM
    Ali3n898
    Alex
    Houston, Tx
    Your cool rush! Anybody an idea or links to a BL? I don't want to shell out 5 grand just to lift my taco
  17. Apr 11, 2015 at 8:25 AM
    5 Lug Slug
    5 Lug Slug New Member
    David
    Alabama
    5 Lug Fabtech lift spindles ADL in rear
    3 in Lift 30' tires
    How much lift did you get with the v6 coils?
  18. Apr 13, 2015 at 5:46 PM
    navin
    navin Well-Known Member
    I did a thread on a 1" body lift on a 2014. I used spacers from Summit Racing and hardware store bolts. Pretty simple as long as you deal with the steering shaft joint. I think on older trucks you can so's was out the u joint in it with washers.
  19. Apr 13, 2015 at 5:47 PM
    navin
  20. Nov 22, 2016 at 8:54 PM
    Brads5luggreenbastard
    Brads5luggreenbastard Active Member
    North Carolina
    03 base 5-lug 2wd 2.4L
