Body Lift HELP?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dj318, Jan 18, 2014.
  1. Jan 18, 2014 at 6:49 PM
    Dj318
    Dj318 [OP] Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Hey, Im fixing to take off my body lift, a local body shop wants $150-200. How hard do yall think itll be to do it myself? What alls involved? and what do you think i will need as far as bolts and what not? Is it worth just taking to him?
    Thanks
  2. Jan 18, 2014 at 6:51 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    That price doesn't seem too bad to me. It's a small hassle.
  3. Jan 18, 2014 at 8:34 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    You'd need a jack, a foot or two of 2x4, hand tools, and some new shorter bolts for the cab maybe even toyota bolts. The steering shaft has an extender on it, thats probably the thing you'd want to be the most careful with, but if you just are careful to keep the wheel straight and the tires straight you wouldn't have any problems.. If you feel comfortable do it yourself and save some $
  4. Jan 18, 2014 at 8:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Probably not too involved, but I've never done one, looks like some spacers set at body/frame points, then again $150-$200 isn't bad
  5. Jan 18, 2014 at 8:50 PM
    jgilbreath
    jgilbreath Well-Known Member
    Kerrville, TX
    99 Tacoma PreRunner
    Husky floor liners, SAWs 2.0
    I am getting ready to do the same. Extensions on steering, shifter, gas fill neck. Replace lift picks with polyurethane cab mount bushings from Wheelers. Lower body slowly and watch out for brake lines. Those are things that came up when i was searching.
  6. Jan 18, 2014 at 8:51 PM
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Thanks! would you know how many bolts i would need total? and are all the bolts the same size? i dont feel to comfortable because everyone i talk to says something different, from steering, 4wd linkage, and radiator supports? kinda makes me question
  7. Jan 18, 2014 at 9:46 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Its kind of annoying and took me about 6-8 hours with help haha Id pay the 150 for sure
  8. Jan 18, 2014 at 9:47 PM
    bellassaiw10
    Currituck NC
    as far as bolts go just order a poly mount bushing kit and it comes with new bolts
  9. Jan 18, 2014 at 9:50 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    If you're not comfortable to do it then don't. You can really mess some stuff up including yourself. When my old z71 was getting the body lift taken off it slipped on the jack and almost crushed the guys hand between body and frame. Spend the money and let someone else do it. Plus if something gets screwed up by them you have someone to blame. If you screw it up you're screwed.
  10. Jan 18, 2014 at 10:16 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    I would pay some one! I tackled mine by myself and it took a while to do, I also did my body mounts too, it is actually really simple, just looks like a lot
  11. Jan 19, 2014 at 4:52 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I did mine year and a half ago and wasn't too bad. The box was quite easy and the only real trouble with the cab was the steering coupling and replacing the body mounts, the steering extender had been jammed onto the shaft by whoever did the original lift and the body mounts were badly rusted. Doing the box only took a couple of hours but the cab took most of the day but being retired I don't work too hard. Just make sure that when you lower the cab down you do it in stages so you can squeeze the little curly-cues in the brakelines together as you drop it. Don't forget the extenders for the radiator and the bumper which also have to be removed. Just go slow and be careful and buy new body mounts.
  12. Jan 19, 2014 at 8:51 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Great little write-up here. Good stuff.
    OP, try doing just the bed yourself, piece of cake. Then, if you feel un-easy about the rest, then at least you'll have lowered the cost to the mechanic to do just the cab.
    Loosen all bed bolts (4 or 6?) first, then remove bolts from one side, jack up that side, remove the lift pucks, replace bolts (don't tighten).
    Repeat for other side. Tighten all bolts. Not sure what you'll have to do about the gas spout, depends on the amount of body lift you are removing.
  13. Jan 19, 2014 at 11:34 AM
    newskooler
    newskooler Well-Known Member
    Nick
    Mount Shasta, Ca
    1997 ext cab base, 2012 Base Access cab, 2018 trd OR
    Mall Crawler
    I've also done the removal. These guys have pretty much summed it up for you. My only advice would be to tie off the steering wheel so that it can't be turned. The clock spring doesn't take much to break and it's a couple hundred dollars to replace.
  14. Jan 19, 2014 at 5:06 PM
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    thanks guys! so far we have the bed completely done and my entire front end blacked out. Tomorrow will be the cab, any other helpful tips besides the steering column? anyone know anything about the radiator?
    And instead of tying off the steering wheel could i just move it till it locks into place, then remove the extender? or is the lock further down?
  15. Jan 19, 2014 at 5:18 PM
    tan4x4
    Rick
    Folsom, CA
    Assuming the radiator has been lowered, there should be re-positioning brackets there, where the radiator is normally directly attached to the radiator support. Un-bolt the radiator (be careful, it will be very heavy if you have not drained it), remove the brackets and re-attach. When I did a 1" body lift, I didn't do this step, instead I removed the lower half of the shroud to clear the fan.
  16. Jan 19, 2014 at 5:32 PM
    newskooler
    Nick
    Mount Shasta, Ca
    Mall Crawler
    I'd imagine the wheel lock would work because it's in the column. but I hadn't thought of using it before. Maybe double of precautions just in case?
    As for the radiator it should just be removing the drop brackets and placing the radiator back in its original position and reinstalling the fan shroud if it was removed.
  17. Jan 20, 2014 at 9:36 AM
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Any one know where the steering shaft extension would be located? And if so what does it look like? Having some trouble finding it.
  18. Jan 20, 2014 at 11:48 AM
    newskooler
    Nick
    Mount Shasta, Ca
    Mall Crawler
    From what I remember It's at the steering rack. Should be a puck spacer between the flanged couplings. Just loosen the and remove the bolts and loosen the collar lift the top coupler and remove the spacer.
  19. Jan 20, 2014 at 2:14 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Changed my rack yesterday. Extended would be right above rack in joint right there. Look right above. Flat rubber pad to dampen steering wheel vibes.
    Steering wheel lock isn't precise. Tie off.
    I broke my clock spring. Hooray!
    Overall pretty easy. I changed all my bolts and bushings in a couple hours on cab.
  20. Jan 20, 2014 at 4:09 PM
    bellassaiw10
    Currituck NC
    There's a few different styles, the puck kind then there's the shaft kind
