Body lift ideas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco4×4, Apr 10, 2016.
  1. Apr 10, 2016 at 7:55 AM
    Taco4×4
    Taco4×4 [OP] New Member
    2015 tacoma trd off road
    I have myself a new 2015 Toyota Tacoma TRD off-road was looking to put a body lift on it can anyone help me with this? I want to get out cheap as possible also if I put a 3 inch body lift what size tires can I put on my truck without any scrubbing?
  2. Apr 10, 2016 at 7:58 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Dont do it.
    ODNAREM likes this.
  3. Apr 10, 2016 at 8:02 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    If your going to be doing some wheelin which i assume you are having a 4X4 don't do a body lift!Do a suspension upgrade!Body lifts are trouble and can cause potential problems!Honestly i'm not even sure if body lifts still exist or if any manufacture offers them!Good luck!
  4. Apr 10, 2016 at 8:04 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    DON"T DO IT.
    ODNAREM likes this.
  5. Apr 10, 2016 at 8:11 AM
    Taco4×4
  6. Apr 10, 2016 at 8:14 AM
    Taco4×4
    Put it this way I want bigger tires and more ground clearance what's the best way to do so with out spending a lot of money?
  7. Apr 10, 2016 at 8:16 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    What is a lot of money?
    Big tires cost more than a proper lift does.
    ODNAREM likes this.
  8. Apr 10, 2016 at 8:19 AM
    Pigpen
    Dan
    Northwest Montana
    They are out there. The general consensus is not to do more than 1 inch body lift on these trucks. There are a few around here who have them to fit crawl boxes more easily.
    Your cheapest way to lift is a spacer lift. These are also not recommended for the changes thay make to suspension geometry. We all understand that you just poured a shitload of money into buying a truck. Modifying your suspension is not a place to save money. Do your research on here before making any modifications - there's a wealth of knowledge available, and this is the most asked question on this website.
    Break out your wallet... Welcome to the TW family!!!
    ODNAREM and Taco4×4[OP] like this.
  9. Apr 10, 2016 at 8:35 AM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Cut the fenders
  10. Apr 10, 2016 at 8:36 AM
    T4RFTMFW
    For that matter, you can't fit a bigger tire with a 3" lift than you can with your truck at stock height, so keep your lift money and put it towards a set of 265/75/16s.
    You'll gain just as much ground clearance without wasting money you don't have on bad ideas.
    If you can't afford to mod, don't mod.
