Body Lift rear bumper gap (Fixes?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sblspawn, May 8, 2019.
  1. May 8, 2019 at 6:25 PM
    sblspawn
    sblspawn [OP] Well-Known Member
    It could be! And maybe I don't even have to relocate the bumper the whole inch. Maybe 1/2 or 3/4 inch is enough to reduce the gap and keep the hitch in the same position. That is good to me! Hey, man! Thanks for your help!
  2. May 8, 2019 at 7:20 PM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    No prob, any questions feel free to ask
  3. May 9, 2019 at 11:15 AM
    christian06
    Cali
    If you dont care about raising the hitch, I think I can make you a couple brackets that will lift only the bumper, just gimme a couple dsys
  4. May 9, 2019 at 12:26 PM
    sblspawn
    Hey, thanks a lot, bro! But I think that it's not possible to make a bracket for the bumper only. The hitch and the bumper mount are attached to the same fucking piece and to make it even worse, It is welded to the hitch. :facepalm:
  5. May 9, 2019 at 1:30 PM
    christian06
    Cali
    There is another way, the hitch Is welded to that bracket, but the bumper is not, believe it or not they are 2 different pieces, I've had my bumper off on more than one occasion, gimme a couple days and I'll get you dialed in
  6. May 9, 2019 at 1:33 PM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    Back in the day me and a buddy did a 2” body lift on his first gen. Instructions told us to take the bumper brackets and flip them over and swap sides with them. It worked perfectly. With the 1” lift it may be different though.
  7. May 9, 2019 at 1:42 PM
    sblspawn
    You're the boss! Whatever you need just let me know! :thumbsup:
  8. May 9, 2019 at 1:44 PM
    sblspawn
    The problem is that I have the OEM hitch and is welded to the bumper bracket. :(
  9. May 9, 2019 at 1:49 PM
    Kennyluu611
    Kennyluu611 Well-Known Member
    Kenny
    SoCal
    2010 Tacoma DCSB Prerunner 4x4
    King 2.5 JBA HD UCA Dakar Rear Leaf US Off Road Bumper Winch 4x4 Converted TRD Supercharger
    You can get this "https://www.ebay.com/itm/233069634906". It's the bracket that comes with Tacoma without tow package.
    sblspawn[QUOTED][OP] likes this.
  10. May 9, 2019 at 3:20 PM
    08RC
    08RC Well-Known Member
    Thats what I did . Mine had no OE hitch so I cut the bracket straight up just to the front of the oblong hole, moved it up an inch welded it back together ( the split end is the front of the bracket ). I added an after market hitch that reinforced the whole thing . I made the cut parallel to the oblong hole that way you go straight up one inch and gusset it how ever you like.
    sblspawn[OP] likes this.
  11. May 9, 2019 at 3:22 PM
    christian06
    Cali
    It's not welded to the bumper bracket, that's the hitch bracket
  12. May 9, 2019 at 3:26 PM
    08RC
    that one will require a bit more thought I can see
  13. May 9, 2019 at 3:33 PM
    sblspawn
    I think that they used the same bracket for the hitch and the bumper. I was today below the truck and this is all I could see. I can take more pics if you want. :)
  14. May 9, 2019 at 3:35 PM
    sblspawn
    Yes, I agree with you! :(
  15. May 9, 2019 at 5:50 PM
    #35
    christian06
    Cali
    It's not nearly as bad as it seems
    randey and sblspawn[OP] like this.
  16. May 9, 2019 at 6:32 PM
    #36
    sblspawn
    Here is a photo of the other side.
  17. May 9, 2019 at 8:09 PM
    #37
    christian06
    Cali
    I get it, I have the same set up on my 06 DCSB prerunner and I e had the bumper off atleast 10 times, the most recent was to spray it with tintable bedliner about a month ago, it comes off separate from the hitch
  18. May 10, 2019 at 7:25 AM
    #38
    christian06
    Cali
    Here u go,
    8=12mm bolts
    2=10mm bolts
    2=17mm bolts
    4=19mm bolts
    To get the bumper, reinforcement bar off. Then there are 1 hole on each side of the reinforcement bar that can be drilled out 1 inch lower with alittle cleaning on the back side of that hole. The other hole is to low to simply re drill. I would weld a tab on it and drill a hole in that, it's as simple as 2 holes on each side, and as you can see, my hitch is still bolted to the frame.20190510_063552.jpg 20190510_063622.jpg 20190510_063947.jpg 20190510_064317.jpg 20190510_064824.jpg 20190510_065233.jpg 20190510_071041.jpg 15574979082283554515126397280853.jpg
  19. May 10, 2019 at 7:31 AM
    #39
    christian06
    Cali
    Oh ya, put back together in reverse order, lol
  20. May 10, 2019 at 7:58 AM
    #40
    sblspawn
    Holy shit! Thanks a lot, buddy! You are the best! I really appreciate all what you have done to help me! :bowdown: So, the idea is just to move those 2 holes 1 inch down on the bar. You know what? Maybe it's a good idea if I try to find one in a junk yard. What do you think?
