Body lift removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dmoe, Mar 28, 2023.
  1. Mar 28, 2023 at 2:03 PM
    Dmoe
    Dmoe [OP] Member
    97 taco 3.4
    Bought me another taco has 3 in body lift no shops will touch it to remove an ones that will say 2k it can’t be that bad too remove it they all crying like babies jack it up remove bumpers an radiator relocation clips an steering extension then remove an Replace body mounts with stock an lower with floor jack is it really that bad
  2. Mar 28, 2023 at 2:05 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I think that depends on the attitude you went into the shops with. If you're telling them it's an easy job, and call them crybabies for not meeting your expectation, I wouldn't want to touch the truck either.
    Madjik_Man, ToyoTaco25 and atc250r like this.
  3. Mar 28, 2023 at 11:54 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    It’s not a hard job, I’d look for the following, most you already mentioned
    -extension at the steering rack
    -extension on the filler neck for the gas tank
    -relocating radiator
    -proper length hardware for the 6 cab mount locations and bed bolts, and obviously whatever goofy shit they did to the bumpers.
    Shops probably don’t want to touch it like I don’t want to touch someone’s house who said he did all his own plumbing watching YouTube, probably don’t want to accept liability for someone else’s hack work
  4. Mar 29, 2023 at 1:05 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Were any parts changed/modified to install the body lift (cut/extended steering shaft, cut/extended fuel filler neck, different plate at firewall where the steering column comes through?
    You will have to repair or source new/used parts during the lift removal.
    Dmoe[OP] likes this.
  5. Mar 29, 2023 at 4:09 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The important question is how much winter Chemicals has the truck seen?
    If you lived near me $2000.00 might be to cheap. Some shops might not be insured for Hot work.
    I removed a body lift all the bolts needed burnt off. I would charge an easy $2000.00 to do another one I would also need to be real hard up for money.
    If the job is that easy why not do it yourself??
  6. Mar 29, 2023 at 6:18 AM
    02hilux
    Planet: EARTH
    Because it's easier said than done :rofl:
    OP want reassurance that $2k is ridonkculous :D
    Bivouac[QUOTED] likes this.
  7. Mar 30, 2023 at 2:52 AM
    Bivouac
    Poor OP must not have liked our answers!!:rofl::rofl::rofl:
  8. Mar 30, 2023 at 9:38 AM
    Dmoe
    Dmoe [OP] Member
    97 taco 3.4
    Yea your answer don’t bother me I am gonna do myself I feel like that’s a rip off living in southern us coast no salt on roads here had loose bolt tightened it right up
  9. Mar 30, 2023 at 9:42 AM
    Dmoe
    Dmoe [OP] Member
    97 taco 3.4
    New to this don’t know how to reply to each comment or it’s not letting me it was done right bumpers both have brackets that moved them as does radiator an steering as I mentioned yes well aware not a 2 hr job for all the smart ass haters that replied an called shops on phone to see what they would charge no bad attitude out of 5 only one would do it an seemed extremely high when they don’t charge that much to do a suspension lift
  10. Mar 30, 2023 at 9:44 AM
    Dmoe
    Dmoe [OP] Member
    97 taco 3.4
    No hack done right at shop in another state
  11. Mar 30, 2023 at 9:44 AM
    Dmoe
    Dmoe [OP] Member
    97 taco 3.4
    All is done right
  12. Mar 30, 2023 at 9:47 AM
    Dmoe
    Dmoe [OP] Member
    97 taco 3.4
    Help by saying I called shop crybabies lol yea fig wasn’t too hard it’s not a hack job done in someone yard it was done right I fig cpl floor jacks to hold each side an all new factory mounts a good day a done not a 3 day job like shop told me
    Taco critter likes this.
