Body Lift vs. Suspension Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LizellaFella, Feb 11, 2013.
  1. Feb 11, 2013 at 7:05 AM
    LizellaFella
    LizellaFella [OP] Well-Known Member
    Eddie
    Reno Nevada
    2016 Tacoma SR5 4x4
    I'm sure this subject has been discussed ad nauseum, but I looked around the forums and didn't find anything specifically comparing the two, so I'm asking for input.
    My son just purchased a new left over 2012 TRD sport DCSB. He's now wanting to do a lift and has asked the pro's and con's of one over the other. I say a suspension lift using either spacers and blocks, or different springs is the way to go. We are only talking 3 or so inches here.
    Thoughts?
  2. Feb 11, 2013 at 7:08 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Body lifts are hideous, and I dont know much about lifting trucks, you can see daylight thru the wheel wheels between frame and bed...
  3. Feb 11, 2013 at 7:12 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Suspension is the way to go...dont do blocks and spacers...
  4. Feb 11, 2013 at 7:14 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    for just looks, if the truck will never go offroad, you could get by with the spacers/body lift. its easy on your wallet too. If your son plans to do any offroading ir trail riding at all, go ahead and do a suspension lift. body lifts are frowned upon on TW simply because they put stress on vital bolts from frame to body. over time , if you did offroad with a body lift, you would eventually run the risk of shearing off bolts. also, there is no ride comfort or suspension gain with a body lift, and no ground clearance from ground to frame.
    but like i said, it depends on what the truck will do. its a matter of getting what you pay for.
    around 300 for a body lift is fine if all the truck sees is a highway.
    if you are gonna hit the trails, then i would justify $1000 + for a proper 3" suspension lift.
  5. Feb 11, 2013 at 7:21 AM
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    A suspension lift raises the entire frame of the truck where the body lift only raises the body of the truck and the frame is the same height. The suspension lift is the best way to go. As you mentioned spacers and blocks, it appears it'll be lifted on a budget. Look into Bilstein 5100 shocks for the front and an Add-A-Leaf for the rear.
    Body lifts should really only be used when necessary and in the smallest increment necessary with all Grade 8 hardware. Their purpose is only to run a bigger tire.
  6. Feb 11, 2013 at 8:20 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I'd go with a nice suspension lift. Even if he won't be doing much off reading. Sure spacers and blocks are the cheapest but you can get a better ride with some new shocks in there. My truck rides better than it did stock since putting my lift on.
    Really depends on budget but I look at it as if you're getting a brand new truck why put the cheapest possible parts on it.
    I'd never do a body lift myself.
  7. Feb 11, 2013 at 9:10 AM
    LizellaFella
    Eddie
    Reno Nevada
    2016 Tacoma SR5 4x4
    Thanks Guys. I appreciate the input.
  8. Feb 11, 2013 at 9:39 AM
    mirraman
    mirraman Well-Known Member
    Tim
    Ventura
    98 4Runner Limited 4X4 e-locker :-)
    99 4Runner springs all around: 1" over factory.
  9. Feb 11, 2013 at 9:51 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Suspension all the way
  10. Feb 11, 2013 at 9:52 AM
    rockgecko03
    Ben
    Rockwall, TX
    ^^ Haha, I'm not sure that counts as a body lift. There's two frames!
  11. Feb 11, 2013 at 10:01 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Some one post up the photo of the cab that was ripped off the frame on a body lifted toyota.
    Yes don't do that.
  12. Feb 11, 2013 at 10:44 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I would have asked the reasoning behind that... I'm so curious to know why
