Body lift what should i get?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedstick43, Feb 10, 2010.
  1. May 28, 2010 at 2:48 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    x2 I have a 3" suspension lift and 2.5" body lift and love it :D
  2. May 28, 2010 at 3:03 PM
    justinfox3110
    justinfox3110 Well-Known Member
    justin
    beckley wv
    07 speedway blue 6 spd
  3. May 28, 2010 at 6:55 PM
    dezert taco
    dezert taco Well-Known Member
    central valley
    J arm longtravel full fiberglass
    it has a J-arm longtravel front end fiberglass fenders hood and bedsides engine cage been rolled need to replace roof
    okay okay okay......listen if you want a body lift get it. they are available everywhere, for cheap. if you wheel your truck alot i wouldnt recomend it.... it will cause more problems in the long run with tweaking things. if you wheel once a month but daily drive your rig then do it. plus 37's will look awesome. but there are other ways to get more lift that are just as cheap as body lifts. what set up do you have now? like suspension wise? toss some pics of your truck up on here
  4. May 28, 2010 at 7:04 PM
    dezert taco
    central valley
    here is a body lift on 35s i think....
  5. May 30, 2010 at 9:36 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    mine has a 3" body and idk how many suspension and rides great, idr where i ordered mine though
  6. Dec 21, 2011 at 7:54 PM
    99yotason
    99yotason New Member
    matthew
    henry
    99 sr5
    4 inch suspension lift, 3 inch body lift, eagle beadlock wheels, 33/12.50's, black badges, halo projectors, tinted talelights, rhino lined bottom
    I ride a 4 in. Suspension lift with 3in. Body lift its a dream!
  7. Dec 21, 2011 at 8:00 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    welcome to the site:wave:
    *must resist the urge to rage*
  8. Dec 22, 2011 at 1:17 AM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    Couldn't he stack a 3 inch coilover lift on top of the 6 inch DB? I though tacoridinghigh did something like that...
    Which would be better? Stacked suspension lifts, or suspension and BL?
  9. Dec 22, 2011 at 1:22 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    a body lift:eek:
  10. Dec 22, 2011 at 1:29 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    welcome to the site. in the future please refrain from posting in a thread from the year 2010. please and thankyou.
    also, f body lifts. uber gaye.
  11. Dec 22, 2011 at 11:43 AM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Whoa whoa whoa. Everyone is throughly encouraged to use the search (which he clearly did)
    Thread revival>repost because too lazy to search.
  12. Dec 22, 2011 at 11:52 AM
    drifter
    Sam
    Oregon
    good stuff
    x2
  13. Dec 22, 2011 at 12:03 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    neither, IMO. stacking suspension lifts exceed the design parameters of EACH lift, and is a bad idea.
    If you want a 6" susp lift, but already have a 3". remove the 3" and get a 6". Don't put spacers on a 3" coilover lift, then add 3" blocks to a 3" AAL in the rear.
    If you want to do a 6" lift (if you want ANY measure of performance) you'll need an entirely new leaf pack, shackles, shocks, and A-arms, shocks, etc... up front. You can't just drop the A-arms down 6" in the front and add a bunch of AALs and blocks in the rear and expect it to not ride like shit. Hell, at that height, you might as well go for a 4-bar and coil-overs and a SAS up front, glass fenders on all corners, and a roll cage. Personally, I think 6" is too much for an IFS suspension anyway. Get a Total Chaos or other long travel kit that extends the length of the A-arms and axles (thereby lessoning the down angle of the axle) if you want IFS with 6" lift.
    Of course, I'm of the mindset that mods like this (lifts) are supposed to *perform*, not just allow you to crawl to the mall with 38 inch tires and doubled Fox reservoir shocks.
    As for body lifts, they also do not "perform". They might allow larger tires, but what do larger tires do (for wheelin'), if you don't also have more travel and higher ground clearance. You do get a higher center of gravity, though.
  14. Dec 22, 2011 at 5:21 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  15. Dec 22, 2011 at 7:28 PM
    #35
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Or you could just cut a little. You already cut your factory crossmember off, so why not do a little more cutting and actually make the truck slightly wheelable. Shit, this guy did it on a 3'' lift and 1'' BL. No need for a massive fawking lift. Unless your a douche bag mall crawlin bro.
    Pretty damn capable
  16. Dec 22, 2011 at 7:29 PM
    #36
    jbrandt
    Justin
    Of course the CG is higher with both types of lifts. The issue for many people here is that there are many other advantages to a susp lift that go along with the negative aspect of a lift. A BL just makes the truck higher with no increase in performance.
    For me, I HATE looking at the side of someone's frame rails. It looks stupid, IMO. It basically makes the truck look like the body was an afterthought, not something that's integrated in to the whole vehicle. It's even better when you can see air between the body and frame. Sure, skirt it, but then all you see is 8" of frame under the body. = no bueno.
    If that's the look you're going for, then go right ahead, I'm not going to stop you. But when someone asks for an opinion on an open forum like this, you're going to get... wait for it... people's OPINIONS... imagine that...
  17. Dec 22, 2011 at 7:39 PM
    #37
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    I laughed alot on this thread......:laughing:
  18. Dec 22, 2011 at 7:42 PM
    #38
    dad32509
    Dave
    San Diego
    Blacked out 05
    Hahaha! Theres alot of dudes like this in SD......and there always cruise with 4 other dudes, and the mad dog EVERYONE! haha!
  19. Dec 22, 2011 at 9:42 PM
    #39
    drifter
    Sam
    Oregon
    good stuff
    Most of what you said there makes sense.
    I remember looking into 4 inch body lifts at one time...I'm glad I didn't do that. Maybe seeing a coworker BL his Ford Ranger helped convince me to do the right thing.
  20. Dec 22, 2011 at 9:45 PM
    #40
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    super dumb:eek:
