Body Lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by 7QUIG8, Jan 5, 2017.
  1. Jan 5, 2017 at 11:57 AM
    7QUIG8
    7QUIG8 [OP] New Member
    Damon
    2012QUADGRAPHITE
    TRD 4 DOOR
    Hi All, I have a 2012 Quad cab TRD Taco. I just ordered TRD matte black wheels with 265/70/17 BFGs All Terrain tires. I was thinking of doing a body lift around 2" and adding wheel spacers. Any thoughts or recommendations from anyone?
    Thanks.
  2. Jan 5, 2017 at 12:55 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    You might have better luck in the 2nd gen section. This is the First gen section.
    eccracer104 likes this.
  3. Jan 5, 2017 at 12:58 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Any reason why you're considering a body lift over a suspension lift? Body lifts leave an ugly gap between the body and frame as well as body to bumpers.
    Also this.
  4. Jan 5, 2017 at 12:59 PM
    eon_blue
    Azusa, CA
    Friends don't let friends install body lifts...go with a suspension lift and do it proper.
  5. Jan 5, 2017 at 1:02 PM
    mataco4wd
    mataco4wd Well-Known Member
    994wd
    Agreed!
  6. Jan 5, 2017 at 1:07 PM
    eon_blue
    Azusa, CA
    Body lifts are cheap and can be dangerous (probably not at 2" but still), and they just look bad in my (and probably most everyone's) opinion. Not to mention, you aren't gaining any real clearance since the frame is still sitting at stock height.
    I assume your considering one because you're not looking to spend a lot, so I'd recommend to look into the Bilstein 5100 shocks for the front/rear. The fronts are adjustable up to almost 3" (not recommended to go that high with them but still better than a body lift). Throw an add-a-leaf in the rear and you're golden. That's a very basic way to lift your suspension but it's far better than a body lift, and can probably be done for around $500. Maybe less if you can score a deal. More if you decide to upgrade your coils.
  7. Jan 5, 2017 at 1:30 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    I'll be the devil's advocate - Nominal body lifts can provide some benefits. The biggest benefit is increased clearance between body and transmission (bell housing). Sure is nice have an additional inch or so of room to get to those top bolts. Also, one can gain some additional clearance from tire to body/fender using BL's. If you are going to do it, do it right. Use quality components such as those you can obtain from Roger Brown / 4Crawler - http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml - Once you get over the terrible website appearance, there exists one of the best rundowns of body lifts (Pros and Cons).
    To each his own
  8. Jan 5, 2017 at 1:39 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    If you must have a BL get one under 2". with those size tires on a 2nd gen i see no reason to get one over just doing some trimming.
