Body lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bigcountry75, Feb 20, 2017.
  1. Feb 20, 2017 at 12:01 PM
    Bigcountry75
    Bigcountry75 [OP] Well-Known Member
    Bryan
    2004 Toyota Tacoma
    3' leveling kit 285/75r16 tires
    anyone know of a good cheap 2inch body lift to get? Need something for my tires to stop rubbing in the front
  2. Feb 20, 2017 at 4:36 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    BFH
    according to your description you already have a 3" "level" :puke:
    beyond that you need to hammer the pinch weld. it will still hit the frame.
  3. Feb 20, 2017 at 5:08 PM
    Bigcountry75
    Bryan
    2004 Toyota Tacoma
    Yes I have 3" suspension AN I've cut banged every thing took it through some trails yesterday AN have a lot of rub was thinking of a body lift would help not hitting the frame I'm hitting the body on the corner
  4. Feb 20, 2017 at 5:39 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    You running any wheel spacers?
  5. Feb 20, 2017 at 6:22 PM
    blairrad
    blairrad Yoter
    Missouri
  6. Feb 21, 2017 at 6:26 AM
    Bigcountry75
    Bryan
    2004 Toyota Tacoma
    Yes 1.5 inch
  7. Feb 21, 2017 at 10:01 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    If you're hitting the back corner of the fender but not the frame, your wheel spacers are too large. Try taking them off the front and see what happens. I bet you'll stop rubbing the fender but it'll start hitting the frame - you probably need a smaller spacer, like 1".
  8. Feb 21, 2017 at 10:04 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    4crawler (aka "Roger Brown") Not the best website, but parts are 2nd to none with upgrade options available as well.
  9. Feb 21, 2017 at 11:58 AM
    Bigcountry75
    Bryan
    2004 Toyota Tacoma
    I put spacers on it because with my tires the tire is less then a half inch away from
    The upper control arm
  10. Feb 21, 2017 at 12:34 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    hockey pucks :anonymous:
  11. Feb 22, 2017 at 10:21 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    then you really only need 3/4" spacers max. the tire won't expand by that much under pressures.
