body Lifts!?!?!? just curious no hard feelings ;)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1YOTA6, Jun 1, 2013.
  1. Jun 1, 2013 at 6:17 PM
    1YOTA6
    1YOTA6 [OP] 1YOTA6
    Kyle
    Rochester, NY
    11 Db cab LongBed Tacoma 4x4 Sport
    ReadyLift 2.75 leveling lift, 1.5inch spider trax wheel spacers, Plasti-Dip wheels and front grill, Under carriage reverse spot lights, OTTRA Switches, wether tech floor mats, Toyo Open Country AT 285-70r17, on the waiting list for HomerTaco Grill :)
    I am just curious as to why this is frowned on the web site?
    Just for the reason that every tacoma owner uses the truck differently and if you are not beating it down out in the woods and jumping ditches and just driving mainly paved roads then there wouldn't really be a reason to spend the money for a bad ass suspension lift just to bring it off the ground more.
    is there more to this than I am not seeing?
  2. Jun 1, 2013 at 6:19 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  3. Jun 1, 2013 at 6:32 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    I think body lifts look like crap.
  4. Jun 1, 2013 at 6:33 PM
    169.254.255.201 Well-Known Member
    Interwebs
    Pass it along..
  5. Jun 1, 2013 at 6:40 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    I don't like being able to see that much frame. Just looks tacky
  6. Jun 1, 2013 at 6:43 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Think about the event of an accident. You've now spaced up your body off the frame and changed how the impact force is transferred from the cab to the frame. That's by #1 reason. I don't beat my truck in the woods but I opted for a suspension lift because the stock suspension is absolutely pathetic and I actually wanted to make the truck better.
  7. Jun 1, 2013 at 6:44 PM
    wrxRome
    Brandon
    You don't gain any up or down travel with body lifts either
  8. Jun 1, 2013 at 6:46 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
  9. Jun 1, 2013 at 6:48 PM
    jmg256
    Al Tonter
    TRD Offroad
    Most suspension kits on the market don't either, only moving the static ride height within the range of travel :D
  10. Jun 1, 2013 at 6:49 PM
    BulletToothTony
    Extended travel do :p
  11. Jun 1, 2013 at 6:55 PM
    Snorkie
    Snorkie JEEP LYFE
    Jeep
    Rubicon
    Prius
    Droop?
  12. Jun 1, 2013 at 6:55 PM
    jmg256
    Al Tonter
    TRD Offroad
    You'll notice I said "most"
  13. Jun 1, 2013 at 7:00 PM
    Pugga
    Massachusetts
    You gain uptravel but lose downtravel with any stock-travel lift.
  14. Jun 1, 2013 at 7:07 PM
    jmg256
    Al Tonter
    TRD Offroad
    On the same note... when you lower the truck using stock travel drop kit you gain down travel
    Pick nits, much?
    I'd also argue that down travel is more 'valuable' than up travel in 90% of suspension systems, so in lifting the truck using a stock travel kit, you gain zero real benefit other than aesthetics.
    Don't argue it's to fit larger tires...to get full use of the suspension, you still need to trim the body/frame if you want to run bigger than a 265/75/16 tire...you can do that with zero lift...trim to fit bigger rubber, that is. The meaningful ground clearance comes from tire size
  15. Jun 1, 2013 at 7:21 PM
    Pugga
    Massachusetts
    I'd counter that argument by saying you upgrade the shocks, better valving, better performance, less fade, a stronger shock, etc. It's not just aesthetics you gain, you get a better suspension.
  16. Jun 1, 2013 at 7:26 PM
    jmg256
    Al Tonter
    TRD Offroad
    And I'd counter by saying, that while you're correct, the quality of the components that make up a stock travel system is not what is being discussed...
    The discussion is focused on the static position of the wheel in the given system, and how that effects the dynamics of said system
  17. Jun 1, 2013 at 7:29 PM
    Pugga
    Massachusetts
    :thumbsup:
  18. Jun 1, 2013 at 7:31 PM
    jmg256
    Al Tonter
    TRD Offroad
    :thumbsup:
    Edited it to make the reading easier... :D
    Typing/editing on me phone sucks
  19. Jun 1, 2013 at 7:36 PM
    RiverBoyTRD
    RiverBoyTRD Well-Known Member
    Jonathan
    San Antonio
    05 TRD OR
    2 Hellas, 3 inch, spiders, grill guard, 285's, BHLM etc.
    Sit in the corners haha;)
  20. Jun 1, 2013 at 7:38 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    then what was the point of spending more on a 4x4?
    if you want to crawl the malls or 4-h club stables should a just got a prerunner 2wd
