Body lifts still lame?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomeat2019, Feb 6, 2020.
Thread Status:
Not open for further replies.
  1. Feb 6, 2020 at 2:12 PM
    Tacomeat2019
    Tacomeat2019 [OP] Well-Known Member
    2001 4x4 / 2013 4x4 dcsb trd or
    I know they used to be frowned upon in my circle. But it’s real tempting to slap a 1 incher under there in order to fit 33”s. Hardly noticeable
    Taco critter, lynyrd3 and cruiserguy like this.
  2. Feb 6, 2020 at 2:14 PM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    Then do it.
    "YOLO"
  3. Feb 6, 2020 at 2:14 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    If you're just driving around, sure, go for it. I think a spacer lift would be less work personally.
    Taco critter, Snaeper and Das it mang like this.
  4. Feb 6, 2020 at 2:15 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    lighthearted and carefree?
    Taco critter, GQ7227, SR-71A and 4 others like this.
  5. Feb 6, 2020 at 2:16 PM
    scocar
    scocar Patron of the Farts
    Gay? Homophobic much? Why don't you just stick your 1-incher under there?
  6. Feb 6, 2020 at 2:17 PM
    Tacomeat2019
    Yeah I did 2.5” with suspension this summer but it wasn’t quiet satisfying enough. Seems like it made my tires look way smaller
  7. Feb 6, 2020 at 2:17 PM
    Twizted
    Twizted 1GR FE
    Rob
    America
    It's making noise?
    Taco critter likes this.
  8. Feb 6, 2020 at 2:18 PM
    Gunshot-6A
    Conner
    Everett, WA
    If you did that much on springs, then you should be able to fit 33s with a little trimming of the cab mount and mud flaps.
  9. Feb 6, 2020 at 2:20 PM
    Tacomeat2019
    Well the flaps are gone so I guess I’m half way there. I’m sure there’s a thread on trimming the cab mounts huh?
  10. Feb 6, 2020 at 2:21 PM
    Gunshot-6A
    Conner
    Everett, WA
    Quite a few.
  11. Feb 6, 2020 at 2:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Pinch weld mod.
    Several people on here with a 2" lift that run 33s; just massage that fender a bit.
  12. Feb 6, 2020 at 2:22 PM
    Tacomeat2019
    Hahahaha got me! Misspelled that one didn’t I!! Oh geez how stupid! Someone buy me a dictionary, am I right?
  13. Feb 6, 2020 at 2:36 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    @Tacomeat2019 cab mount chop is not necessary on first gens...
    There are TONS of threads on how to fit 33's on first gen Tacomas.
    2-3" lift, hammer the pinch weld.
    Things are made easier if you carefully select the right wheel backspacing, and perhaps don't get super fatty 33's
  14. Feb 6, 2020 at 2:47 PM
    Tacomeat2019
    I think that’s partly what’s holding me back. I put on some 2018 stock wheels partly because they looked good and partly out of necessity but now my tires are deep inside the wells
  15. Feb 6, 2020 at 2:49 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Different backspacing.
    You can fix that with some quality wheel spacers; it'll push your wheels out away from the frame but the possibility of rubbing with your fenders is still there.
    As I mentioned above, pinch weld mod.
    Tons of information on it, including a write up by @turbodb
    https://adventuretaco.com/finally-the-pinch-weld-mod/
  16. Feb 6, 2020 at 2:51 PM
    jbrandt
    Justin
    Yep, that's pretty common.
    People will fix that with wheel spacers, but those are about as lame as body lifts, lol...
    But I'd do the wheel spacers before a body lift. Make sure you get hub-centric ones.
  17. Feb 6, 2020 at 2:51 PM
    Tacomeat2019
    Cool thanks. I’ve considered wheel spacers a time or two but when researching, I always see mixed opinions on them. Also I’ve heard some tire shops won’t mess with your rig if you have them??
  18. Feb 6, 2020 at 2:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hence why I used the word "quality"
    Spidertrax is one company that I know of, can't say anything about the rest. And to ensure you have no issues, follow the proper procedure for installing as well as torqueing everything to spec. Don't half ass any part of this.
    And yes there are plenty of shops that won't mess with a wheel spacer cause they don't want the liability, but aside from getting new tires, your truck shouldn't be seeing a shop at all.
    DIY I say.
  19. Feb 6, 2020 at 2:54 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I'd make sweet loving with any dude in a lifted Tacoma, especially if it's a body lift :cheers:
  20. Feb 6, 2020 at 2:55 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    There's nothing wrong with a body lift. And, if what you're looking to do is clearance larger tires, then a small body lift will do a much better job at that than the suspension lifts that everyone talks about as being "better."
    There are two reasons for that - first - people are comparing suspension lifts to block lifts (for the suspension components). Second, they hear about a 1" body lift and figure that's the same thing as a block lift, since it's not a suspension lift.
    Here's a good article that talks about the differences, and why a body lift might be a good thing for you, for clearancing. Note: in your case, I'd probably add some wheel spacers (or even change up the wheels to something with more appropriate backspacing) as well/first.
    What size tires fit my lifted Tacoma?
Thread Status:
