Body Mount Bushing Install - now with pictures! And a video too!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, May 18, 2016.
  1. Dec 3, 2017 at 8:52 PM
    #381
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    As bad as my radiator mount bolts were, i’m doing cab bolts just as a precaution. Buy once cry once, one and done kind of thing
  2. Dec 3, 2017 at 9:12 PM
    #382
    Kristi with a K
    Kristi with a K Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    AR15xAR10[QUOTED] likes this.
  3. Dec 3, 2017 at 9:56 PM
    #383
    AR15xAR10
  4. Dec 4, 2017 at 6:04 PM
    #384
    Kristi with a K
    Western MA
    So I took it back on the highway. Getting a vibration at 65-70. It's worse when I veer left. I routed around on here a bit & found wheel bearings &/or driveshaft alignment. Oh, & i do have, & have had forevers, the take off shudder.
    I had looked up a while ago how to check the bearings (the tire check), however I did not know that this might not be enough of a check up.
    As far as the driveshaft goes, the fact that I put on mounts where there were virtually none & flipped the position 2 mount may have had an affect. & it's good to finally see a name put to the "face".... The Takeoff Shudder....
    The other thing that is still there, but to a lesser degree, is a passenger side wave, as if I need a strut. This is where this whole thing (mounts) started. The passenger side wave. The drivers side shock had snapped, so that one was an ICU type deal. I started to feel the passenger wave, so that one got done as well, but the wave persisted. Anywho, (just call me short story long Kristi) looking up this, looking up that checking this, checking that & finally one day my sis who is very heavy was in the truck & I took a left & there was a not so good grinding/rubbing sound. So I had a looksee & noticed how close the cab was to the frame & looked up what keeps the cab on, yet off, the frame & boila! So yeah, the wave is till there. Any ideas on that? Could it be connected with either the bearings or the driveshaft? & somehow the mounts did lessen the wave....
    Now just to let you know, I have done very little to the truck. Brakes, the carrier bearing, an ignition coil, fuel filter, o2 downstream & change the oil every 5,000. Catalytic converter, shocks & a ball joint were all done by a mechanic. So no bushings, springs, belts, etc. I got it at 80,000 & it now has 215,000.... I am saying all this cuz ever since I joined this forum I have needed to confess because it is the first step to changing one's ways.... Money is an issue, but if I can get the help through here, there is hope. & money is an issue, so keeping up on the truck is the way to go, plus she deserves it. So that's one reason I am confessing. The other is that it might help you to know what has not been done, rather than what has. :oops:
    Torspd likes this.
  5. Dec 4, 2017 at 10:15 PM
    #385
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Tacoma TRD OR, '00 Integra GS-R, '75 C10
    King, TC +2"LT, 35's, Aluminum this and that.
    "Take off shudder" might be axle wrap from tired leafs.
    Kristi with a K likes this.
  6. Dec 4, 2017 at 10:41 PM
    #386
    Pigpen
    Pigpen [OP] My truck is never clean
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    It is possible that the take off shudder might be axle wrap. Since you drive a gen 1, it wouldn't be my first suspect.
    You def do a good job of making a short story long :p
    I'm thinking you had driveline vibes that you were not noticing before, but the firmness of the bushings made more noticeable. Your drive line angles might need to be cancelled, or you might just need u joints. I'm not sure what you mean by "wave". Maybe you can elaborate more.
  7. Dec 5, 2017 at 4:27 AM
    #387
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How choppy are the treads on your tires?
    Are your U-joints greasable?
  8. Dec 5, 2017 at 4:46 PM
    #388
    Kristi with a K
    Western MA
    It's a gift :humble:.... Well, depends on who ya ask....
    The wave - when I hit a bump while moving along, as opposed slow, stop & go, the passenger side keeps the bounce a pinch too long, like a sailboat going over waves. In other words, it doesn't pass the bounce the truck test when the passenger side is pushed down & released. It does not return to a standstill after one bounce.
  9. Dec 5, 2017 at 4:47 PM
    #389
    Kristi with a K
    Western MA
    Tires are pretty good & yes. the U-joints are greasable....
  10. Dec 5, 2017 at 5:54 PM
    #390
    Pigpen
    Northwest Montana
    Sounds like you need shocks
  11. Dec 5, 2017 at 6:18 PM
    #391
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Be thankful. Can't be as bad as this....:laugh:
    https://www.instagram.com/p/BcViaj0jMCP/
  12. Dec 5, 2017 at 6:18 PM
    #392
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    When is the last time that you have greased them?
  13. Dec 5, 2017 at 6:54 PM
    #393
    Pigpen
    Northwest Montana
    Torspd[QUOTED] likes this.
  14. Dec 6, 2017 at 4:20 AM
    #394
    Kristi with a K
    Western MA
    Well that's the weirdness that I put in my short story long (you were probably snoozing by the time i got around to this part) is that I have two new fronts already.
  15. Dec 6, 2017 at 4:44 AM
    #395
    Kristi with a K
    Western MA
    I believe I did the carrier bearing in may or June & greased them then.... or was that last year.... :confused:
    Um, yeah.... I can do that....
  16. Dec 6, 2017 at 5:48 AM
    #396
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you taken a good look at the transmission mount? Or was that covered in your Epic? Use a pry bar and see if the the trans is no longer attached to the mount.
    Engine mounts? Have someone rev the engine while you watch to see how far the engine torques to one side.
    How are the leaf spring bushings?
  17. Dec 6, 2017 at 7:50 AM
    #397
    Pigpen
    Northwest Montana
    Should be done every 5,000 miles at a minimum
  18. Dec 6, 2017 at 10:26 AM
    #398
    BadBrains
    AL
    Not to be a party pooper, but your truck needs it's own thread as this is past body mounts.
    Crom likes this.
  19. Dec 6, 2017 at 3:29 PM
    #399
    Pigpen
    Northwest Montana
    Welcome to TW
  20. Dec 6, 2017 at 3:41 PM
    #400
    NaZRaQ
    NaZRaQ Well-Known Member
    Zee
    Denver
    08 TRD off road DCSB
    AR15xAR10 likes this.
