Body Mount Relocate Kit (RedGoatFab & Haws)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Haws, Feb 9, 2015.
  1. Feb 21, 2015 at 9:10 PM
    #61
    clupi
    clupi Well-Known Member
    Sacramento Ca
    07 taco 4x4
    Thanks Shawn and RedGoatFab for the relocation kit, like I've replied in some PM's ive had from TW members the cost of the kit is well worth it.
    Thanks for the hard work and for working on them a second time even though the first prototype was good
    PS: the bolt for the new hole is a hair big to fit through the body mount bushing so I used the factory bolt. I guess you can even take it out of the kit to save on cost on your end :D
  2. Feb 23, 2015 at 2:12 PM
    #62
    Haws
    Haws [OP] Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I happy it turned out for you. Sorry if I was MIA for the last few days, as I would have liked to have follow your progress.
    Your right on on cutting down the kit for a "no body-lift application. We figured it was easier this way then trying to design multiple kits. Good luck on the rest of your build!
  3. Feb 23, 2015 at 5:51 PM
    #63
    clupi
    Sacramento Ca
    07 taco 4x4
    the way you offered kit was perfect,it's nice because you can use it with a body lift or cut it down if you are not running a body lift. Leaving the top part of the factory mount works out great as a gusset, a point of reference for the height and I put a couple more gussets and boxed in the front of it since I did cut it down. Overall I was happy with the purchase, if you habe a little metal work skill its a strait forward install. The only thing would be good for future customers is to include a general step for the install which includes to drill the hole in the floor board pretty much last :D I messed up a little and had to make a second hole, it was a easy fix. Thanks
  4. Feb 24, 2015 at 2:18 PM
    #64
    RedGoatFab
    RedGoatFab Member
    Gary
    Southeast Washington
    Owner of Red Goat Fab
    Clupi Thank You for the feed back on the kit.
    Glad you were happy with the kit over all.
    Gary
  5. Feb 24, 2015 at 2:37 PM
    #65
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I have the kit now. I want the ability to run 35" tires eventually with minimal oter mods. I do not plan on a body lift, so how much do I cut off? Or will it be obvious once I get my head in the fender well. On the other hand if I were to install the body mount kit set up for a 1" body life will this make the 35" tires easier to fit (less hammering on the inner fenders, etc.)? I have no issues with flattening a pinch weld, but beating the hell out of the firewall just seems wrong and asking for trouble down the road.
  6. Feb 24, 2015 at 2:53 PM
    #66
    clupi
    Sacramento Ca
    07 taco 4x4
    Check out the third page posts I left, I wrote in detail how much to cut and what I did for a No Body Lift. And you can still do a body lift later if you want just as if it was stock except you will have more clearance. If you do a body lift with the body mount relocation you will make more room on daily driving or with stock suspension but anything more than 33" you need to clear the firewall in order to have up travel with mid travel or LT
  7. Feb 24, 2015 at 2:54 PM
    #67
    clupi
    Sacramento Ca
    07 taco 4x4
    Thanks for taking on the project and doing a great job on it : D
  8. Feb 24, 2015 at 8:31 PM
    #68
    clupi
    Sacramento Ca
    07 taco 4x4
    So I checked out your front build page and noticed you have mid travel. Does mid travel TC move the wheels forward at all? With my 3" front lift and stock control arms i cleared my body mount chop(before the relocation) with 33" by 1.5" so im sure i could have fit 35s' just fine. 36" which you are running depending on back spacing and set up is close no matter how you chop the factory mount. I like the relocation mount cuz its cheap at less than $100 and with a little work its way out of the way! Look at worst case senario... what if youre going 30 mile an hr on a fire road and hit a pothole or rock. Now you 1/4" or 1/2" clearance just made your truck non opp. I figure the more romo you have to spare the better off you are :D
    In the picture attached im at full lock and have plenty to spare, haven't checked on up travel cuz of my stock coils. If id have LT id have even more room because of less swing without the wheel spacers
  9. Feb 24, 2015 at 8:56 PM
    #69
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    I do not believe it moves the wheel centerline forward, at least not that I could tell. I agree that the more space the better but I've stuffed my tires from lock to lock full stuff and the only thing it hits is the frame rail itself which can only be solved with wheel spacers and that will only move the rubbing to elsewhere so I choose to just limit the steering on the tighter turns. I'm running a 4" backspace wheel 16x8 so not sure how that plays into the clearance. I don't have a great picture but you can see there isn't a whole lot of room, I also didn't chop the "ear" off the stock mount and left that on. This is the same cab mount chop I had originally did for the 33" tires and I did not have to modify it. I'll see if I can get a better picture this week.
    3E049857-B337-442B-8A66-99A50705A5EC_zps_a68645a92b9e7b3f40c10b2ef59825ca8f23a12b.jpg
    176695D8-B65E-4D35-8010-150F7054A98A_zps_461d9ad7b61eb6c92575d837a6eea4e83110ecd6.jpg
  10. Feb 24, 2015 at 10:25 PM
    #70
    clupi
    Sacramento Ca
    07 taco 4x4
    I cant believe youre running 36's without wheel spacers :)
  11. Feb 24, 2015 at 10:27 PM
    #71
    skygear
    skygear                    
    the proper question is, what is the back spacing on the wheels
  12. Feb 25, 2015 at 3:20 AM
    #72
    PSU Taco85
    optional
    4" backspace. Clears the uca nicel as well as the steering knuckle gussets :D
  13. Feb 25, 2015 at 4:49 AM
    #73
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Good to know, Thanks.
  14. Mar 5, 2015 at 9:43 AM
    #74
    R09ster
    R09ster Well-Known Member
    Josh
    OK
    06 SSM DCSB TRD Sport
    debadged, Bilstein 5100 all around (fronts at 1.75" sport coils), Skyjacker softride 1.5" AAL, Firestone Ride Right Airbags, 17X8.5 Method NVs, 285/70/r17 Falken Wildpeak AT3W, US Offroad hidden winch mount, grillcraft grill, Sypder Auto projector headlights, blackedout LED taillights, bed extender, bedrack w/CVT Mt Shasta tent,
    sub'd
  15. Mar 19, 2015 at 5:58 AM
    #75
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Thanks Redgoat/Haws kit received!
  16. Mar 21, 2015 at 10:14 AM
    #76
    Large
    Large Red
    SMKYTXN & I are installing mine now, will update with some nice pics. Haws, any reason you installed your bolts upside down?
  17. Mar 21, 2015 at 10:40 AM
    #77
    Large
    Large Red
    Actually ran in to a big problem :goingcrazy:
    The sets that red goat fab have shipped out were mocked up with a 2" body lift in mind. Meaning that these brackets do not fit if you DON'T have a body lift. Learn from my mistake, I am at the point of no return here and Nathan and I will have to make provisions.
  18. Mar 21, 2015 at 10:45 AM
    #78
    Large
    Large Red
    I guess this was a thing lol. Should have read the thread before cutting off the OEM cab mounts, in any case these pics are great! Thanks. Will supply pics afterwards.
  19. Mar 21, 2015 at 4:08 PM
    #79
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Wish I would have seen these pictures before tearing into Cody's truck. Oh well, the driver side is done. I'll let Cody post the pictures. We'll tackle the passenger side another day.
  20. Mar 22, 2015 at 6:09 AM
    #80
    Negative1
    Negative1 Well-Known Member
    Seems like a solid product. If only the design was also available for those without Body Lifts.
