Body Mount Replacement Options for 1st gen??
Discussion in '1st Gen. Tacomas (1995-2004)' started by NurseJenny, Jan 12, 2022.
  1. Jan 12, 2022 at 7:25 PM
    NurseJenny
    NurseJenny [OP] Member
    Jenny
    Tacoma, WA
    2003 Tacoma 4x4 DC TRD
    Hey, I am in the middle of a core support, fender, and bumper replacement (along with timing belt and valve cover gaskets). . .
    The damaged side should get the front mount bushing replaced, however, all I can find are the poly replacements from Energy Suspension. I currently have poly bushings to change out on the CAs, rack, and sway bar along with an Old Man Emu kit for front and rear. I was really hesitant to do poly body mounts because, in my mind, this would cause too much added vibration/noise.
    Are there OEM style rubber bushings available for the body mounts? I have tried searching but no luck.
    To those with poly, is there a noticeable difference? My honest concern is really my sound system but I do have added floor and door dampener. If I'm being crazy, I'll order the ES mount bushings.
    Cheers!
  2. Jan 12, 2022 at 8:37 PM
    NurseJenny
    Jenny
    Tacoma, WA
  3. Jan 12, 2022 at 9:13 PM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    I used ES when I replaced my cab mount bushings and it was a mess. The ES kit is for regular and extended cabs. They do not work for dcabs. I went round and round with ES tech support trying to get the right combination of bushings. In the end, they sent a second set of tall rear cab corner bushings and I have to have 4crawler.com make me a new set of corner body lift bushings the were 1 3/8"(have 1" body lift) to compensate for the final ES bushing still not being tall enough.
    After all that everything is now the right height, but if I did it again, I would have done factory bushings to prevent the headache.
    As as noise and such by going from rubber to poly bushings, maybe a little , but it is discernable.
    NurseJenny[OP] likes this.
  4. Jan 13, 2022 at 3:53 AM
    snaggs
    snaggs Well-Known Member
    Shaun
    Nova scotia , Canada
    2001 tacoma sr5 2.7 4x4
    None
    I used enery suspension ( black ) ones on a s10 xtreme the girlfriend had a few years ago and didnt notice any differance in ride quality.
  5. Jan 13, 2022 at 5:24 AM
    NurseJenny
    Jenny
    Tacoma, WA
    Great information, thanks!
