Body Roll
Discussion in 'Suspension' started by mattioss, Aug 14, 2009.
  1. Aug 14, 2009 at 1:45 PM
    mattioss
    mattioss [OP] Well-Known Member
    Milford, De
    08 Prerunner DB TRD Sport
    None
    Hey Gents,
    I feel as though the body roll on my truck is excessive. I know there is no rear sway bar correct? (2008 Double Cab Prerunner) Is there anything that can be done to eliminate some of the body roll? And I will be lifting it 3 inches probably next summer after i finish my monte carlo ss.
  2. Aug 14, 2009 at 1:49 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    You should have an anti-sway bar unless you removed the OEM equipment. There is always the option of installing an aftermarket sway bar for the rear.
  3. Aug 14, 2009 at 2:13 PM
    mattioss
    Milford, De
    None
    yeah the factory one is there, i was talking about the rear. so there is one that can be installed? is there a website to it?
  4. Aug 21, 2009 at 8:35 AM
    huntingskeetman
    huntingskeetman Member
    Olmsted Falls - Ohio
    Tacoma 4WD Access Cab
    You might want to consider the Roadmaster Active Suspension unit on your truck. I'm contemplating getting one for mine before the fall. JC Whitney has them and is now offering free shipping. Below is link about unit.
    http://www.activesuspension.com/
    Good Luck, Gary
  5. Aug 21, 2009 at 8:39 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    oh you can lower it to get less body roll. but that would be pointless since your lifting it
  6. Aug 21, 2009 at 8:41 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Having the rear leaf TSB done on my truck reduced my body roll significantly. Like you, I felt it was drifting all over the place stock. Feels MUCH tighter now.
    Edit: Roadmaster looks like a nice unit. Might have to look into putting a couple of those on along with my lift when the time comes.
  7. Aug 21, 2009 at 9:40 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Check Hellwig and Addco to see if they offer a swaybar for your application.
