Body seam sealer recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Jun 18, 2024.
  1. Jun 18, 2024 at 9:33 AM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    What do you all recommend as a body seam sealer for under fenders, and in wheel wells, etc? I have a hard time thinking the speciality stuff can be much better than a quality outdoor type silicone or outdoor window caulk that I would use on a house.
    Recommendations and opinions welcomed.
  2. Jun 18, 2024 at 9:40 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    kidthatsirish[OP] likes this.
  3. Jun 18, 2024 at 10:32 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    used this for sealing up pinch weld area in wheel well... worked great. Outdoor house silicone chalking tends to shrink/crack over time.
  4. Jun 18, 2024 at 10:36 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Specialty automotive stuff will 1000% be better than random "exterior" silicone caulking from Home Depot. I don't know about you, but in my experience I regularly see failures in homeowner grade caulking and sealants from the big box stores. But I've essentially never seen automotive seam sealer fail.
  5. Jun 18, 2024 at 2:30 PM
    kidthatsirish
    Now that you mention it my experience has been the same...good point!
    Maybe we should be using automotive grade stuff on our homes!
  6. Jun 18, 2024 at 2:33 PM
    clenkeit
    Colin
    Lakewood, CA
    Seriously.
    I've had good luck with "construction adhesives" but when it comes to caulking it seems like nothing actually works that well. Latex. Silicone. Clear. Colored. Interior. Exterior. Doesn't seem to matter but it always seems to fail one way or another.
