Body size and height for a Tacoma ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by POPE125, Jun 12, 2019.
  1. Jun 12, 2019 at 6:45 AM
    POPE125
    POPE125 [OP] Well-Known Member
    I have been driving trucks since 1988 , never owned a Toyota and never a smaller truck . My question is Im 6'2 and 235lbs am I going to be to big for a Tacoma ? Wondering if anyone is my size and how you fell in the truck? Cramped ?
    Aldo98229 likes this.
  2. Jun 12, 2019 at 6:47 AM
    Taco16LB
    Taco16LB Well-Known Member
    Every one is a little different , best to go test one out for yourself .
    I am 6' and 250 and fit fine .
    And welcome to TW
    Edit - I also have a sunroof .
  3. Jun 12, 2019 at 6:48 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    6' 1" and 225 and all is good.
  4. Jun 12, 2019 at 6:48 AM
    timlovestacos
    timlovestacos Well-Known Member
    Tim
    Orange County, CA
    2018 TRD 4x4 OR Silver
    6’2 and 205lbs with no problems either. Maybe find one on Turo or another rental car place to drive for a few days and see how you fit.
  5. Jun 12, 2019 at 6:53 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    You'll fit if you want too. I'm 6'4 300lbs and I squeeze into a first gen which has a way smaller cab.
  6. Jun 12, 2019 at 6:57 AM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    Yeah, Just need to sit in it. Everyone is built different. I have an off-road with a sunroof and if i sit with good posture my head hits the roof. I have to lean to the side a bit where my head gets a little clearance from the sunroof or slouch a bit and I'm 5'10".
    If you like to sit with the seat leaning back a bit you should be fine.
  7. Jun 12, 2019 at 7:07 AM
    LameOtter
    LameOtter Well-Known Member
    Bill
    18' Tacoma SR5
    Depends on how long your legs are compared with how long your arms are. I'm 6' 190 and only fit ok. I think I have long legs compared to some people, so in order to have the seat where I would normally like it, I can't reach the steering wheel comfortably. I have to compromise and scoot the seat up a little more than I normally would. They should have either made the seat higher, or made the steering wheel telescope out farther.
    Your best solution is to just try one out.
  8. Jun 12, 2019 at 9:10 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    6’1 300 fits like a glove
  9. Jun 12, 2019 at 9:14 AM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    6'1", 205 and fit ok until I try to get my wallet/phone out of my pocket..steering wheel doesn't tilt high enough
  10. Jun 12, 2019 at 9:15 AM
    Atl_taco_
    Atl_taco_ Well-Known Member
    Sam
    ATL
    2017 MGM OR
    :worthless:
    lol... go test drive the truck.
  11. Jun 12, 2019 at 9:16 AM
    electricdgm
    electricdgm Well-Known Member
    Doug
    Florida
    2019 Cement TRD XSP Sport 4x4
    I as well am 6'0" weighing around 200 and have no problem. For me once I found my sweet spot I leave all the adjustments alone. I did put a 2" level kit on the front so I can fit right in.
  12. Jun 12, 2019 at 9:22 AM
    Mizzou Taco
    Mizzou Taco Active Member
    Kansas City, MO
    2018 TRD Pro White
    6-6 and 275. No issues. Well at least the same issues as every other car or truck that I’ve been in.
  13. Jun 12, 2019 at 9:39 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    You are going to get as many different responses as there are members on here.
    There are tons of variables: height, weight, whether you have a long torso or long limbs, your idea of what a comfortable position is, etc.
    I am 6’0”, 185 lbs, with longer torso than limbs: I don’t find Tacoma’s seating position very comfortable. For me Tacomas cabin lack vertical space, and the seat is too close to the floor.
    I’ve spent a fair bit of time and effort trying to figure out how to be comfortable: I have to set the seat far back in order to find sufficient headroom, but then the steering wheel is too far forward. And then when you sit so stretched out you find yourself with little lateral support. My leg was cramping up after 45+ minutes. I stuffed 1/2-inch worth of washers under the seat rails and that helped quite a bit. There are vendors on this forum selling seat raisers to address this issue.
    Of the midsize trucks I test drove, I found GM’s Colorado/Canyon to offer the most spacious cabin.
    I don’t know if you will find Tacoma’s cabin comfortable or not; my hunch is that coming from full-size trucks chances are you will find Tacoma cabin too small.
    Good luck!
    Taco16LB likes this.
