Body Work...
Discussion in '1st Gen. Tacomas (1995-2004)' started by WASTE MANAGEMENT, Oct 21, 2010.
  1. Oct 21, 2010 at 1:27 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT [OP] Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    i'm ready to start the body work on my truck, anyone know what grit sandpaper to use to ruff it up? Im going to use a DA sander, but I need to take it down to the steel on the hood to get the rock chips out, and just ruff up the rest. I got like 4 door dings that I need to take out. Any good advice would help, i'm a first time body guy.
  2. Oct 21, 2010 at 4:35 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Depending on how much you want to take off, start low and keep progressively going to a higher grit. If you really want to do some damage, something in the 400 - 600 grit will do a number on paint. If you're just doing minor prep, I'd start around 1000 and work up from there. What exactly are you trying to do, are you using a filler to fill in dents or are you trying to sand to remove scratches and paint dings?
  3. Oct 21, 2010 at 5:48 AM
    WASTE MANAGEMENT
    Travis
    Umatilla Florida
    Yeah im using body filler to fill in the dings, but im painting the rest too, so I need to sand it to the point paint will stick well.
  4. Oct 21, 2010 at 5:56 AM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    IMO i would use a 60 grit disc on areas you plan to use filler,(more scratches=better adhesion)then after the filler is dry, use lighter grits (on a block) up to around 320 grit . anything you plan on painting over you could use 400 grit on a DA just make sure you feather the edges down in an area at least 5 times the size of the bare steel so you dont get dimples. also be sure to use a good primer/filler and wetsand with 600grit before paint.
  5. Oct 21, 2010 at 5:56 AM
    Pugga
    Massachusetts
    If you're just sanding so paint will stick, you don't need to rough it up much. Depending on the paint job, 1,000 - 1,500 grit will rough it up enough. You don't want it rough because automotive paint won't cover like say rustoleum and will show the marks from the intial sanding if you used something like 400 grit. I should clarify, I'm not an expert by any means, my experience comes from repainting a motorcycle. I learned a lot of valuable lessons about paint!
  6. Oct 21, 2010 at 3:51 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    if you are stripping the hood down to metal id go with some air craft stripper...then use some 80 grit to hit any rust then a good epoxy to seal it then filler then sandable primer paint etc
  7. Oct 21, 2010 at 4:09 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    +1 for aircraft stripper. That stuff is magic on metal painted surfaces.
  8. Oct 21, 2010 at 4:24 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
  9. Oct 21, 2010 at 7:00 PM
    WASTE MANAGEMENT
    Travis
    Umatilla Florida
    I have heard the aircraft stripper is good stuff, I think I will use it.
    I'm doing a lot of prep hoping it turns out good, today I removed the brush guard, grill, front lights, drivers side mirror, door panel, weather striping, ext cab window glass, inner fenders, fuel door, tailgate and rear pumper. I plan on taking the bed off tomorrow, and doing the passenger side, and front bumper, along with the back glass. We will see how much I get done before dark, at sunset the bugs here and big enough to fuck chickens...
