Body Work
Discussion in '1st Gen. Tacomas (1995-2004)' started by Marshallberger, Mar 2, 2010.
  1. Mar 2, 2010 at 7:24 PM
    Marshallberger
    Marshallberger [OP] Active Member
    Marshallberg NC
    04 Tacoma PreRunner SR5
    K&N cold air intake, 3 inch coil spring spacers, 2 inch blocks, throttle body spacer, red and black custom painted interior, chrome mirrors, chrome door handles, nerf bars, chrome tailgate handle, texas style dual exhaust with flowmaster 50 series muffler, tonneau cover
    My 04 double cab tacoma came stock with fender flares. I took the fender flares off and replaced them with chrome fender trim. The fender trim doesn't completly cover the small holes that the fender flares left behind where they were mounted. Does anyone have any idea how to fill in these holes without having to repaint the entire truck?
  2. Mar 2, 2010 at 7:25 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    chrome fender trim, like chrome bushwackers? ewww
  3. Mar 2, 2010 at 7:26 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
  4. Mar 2, 2010 at 7:30 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    if you can bondo from the back side and then sand and touch up paint. (spray kind only) best bet unless you want to put the old ones back on
  5. Mar 2, 2010 at 7:31 PM
    Marshallberger
    Marshallberg NC
    not bushwackers! l_bc17d8c4a28e46f79d623509a7b12ea1_8abd362d8b36c2418a1dab879267157ff65f336f.png
  6. Mar 2, 2010 at 10:10 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    03 DCSB
    magnaflow cat back exhaust, K&N filter, gray wire, deck plate, ome 883's, ome dakar leafs, bilstien 5100's, blacked out grille, AVS bug shield & window vents, arb bull bar, hella 5in lights, mile marker 8k winch, debadged tailgate, energy steering rack bushings, custom rear bumper w/ hidden receiver, custom headache rack, ome greasable shackles, 4.88's w/solid spacer, SS extended brake line
    to do it right you will have to grind around the holes to bare metal weld them shut then grind , primer ,and paint them you dont have to paint the entire truck just both fenders and both bedsides
  7. Mar 3, 2010 at 1:01 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Some type of clips? Or if not, then bondo.
  8. Mar 3, 2010 at 11:34 AM
    jonny
    jonny Betty White Edition Heep ZJ
    i would put the fender flares back on IMO
    not a fan of the new chrome
    but if you like them, thats all that matters :thumbsup:
  9. Mar 3, 2010 at 11:45 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    x2
  10. Mar 4, 2010 at 5:38 PM
    guamboy
    guamboy New Member
    Ray
    Sacramento
    01 tacoma 4wd
    Very expensive to do it right if you don't like the black flares you can have them painted at a much lower cost and put the chrome flares on your lowrider.
  11. Mar 4, 2010 at 7:20 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Maybe get some torx or allen head screws with washers and have a line of bolts color matched. Or like CMACK said get some plastic plugs.Bbetter than holes in the fenders but still not right.
    Best fix is put the flares back on. Second best is weld up the holes grind it down and paint.
  12. Mar 5, 2010 at 1:36 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    '01 Limited DoubleCab 4x4
    3" SL, Nerf Bars, 33" BFGs, K&N, Deckplate, Royal Purple
    Put the flares back on! They look cool. If yours are black, paint them to match. It looks a lot better than that chrome fender trim. Didn't you hear? Chrome is out! ha ha
  13. Mar 5, 2010 at 1:42 AM
    dustinuhls
    Manhattan, KS
    I wondered that too... If they're gonna crush the truck, why not strip every part possible from it before you turn it in? I'm talking seats, dash, fenders, beds, etc. Is there any restrictions on that? I mean, someone should be getting use out of these parts shouldn't they???
