Bogging/Shaking at Low RPM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dimead0zen, Apr 18, 2022.
  1. Apr 18, 2022 at 7:00 PM
    dimead0zen
    dimead0zen [OP] Well-Known Member
    So Cal
    Mid-Travel 2016 TRD Off-Road 4x4
    Desert prerunnin', rock crawlin' machine!
    Hello! Hoping to find some answers with a new post since I can't see anything similar.
    I have a 2016 V6 4x4. I lifted it at like 20k miles (3in all around), put 285's on, and had a minor driveline vibration at start of acceleration ever since. Now the truck has 80k miles, and I just noticed a severe bogging/shaking/shuddering coming from the mid-rear of the truck at 1,500 RPMS going from 1-2nd gear, and from 2nd-3rd.
    I installed the driveshaft spacer from OME to try to correct it. The vibration at start went away, however the bogging/shaking continues.
    Is it possible I damaged the CV's/Driveshaft? Or does this seem like a transmission issue?
  2. Apr 18, 2022 at 7:04 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Trans fluid change been done at 60t miles? Is it like a shudder? Seems like a failing torque converter
  3. Apr 18, 2022 at 7:06 PM
    dimead0zen
    So Cal
    Yes I would definitely describe it as a shudder. Yes, I believe the trans fluid was changed at 60k miles at the dealer.
  4. Apr 18, 2022 at 7:08 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Might be the torque converter failing. . Hopefully dealer will give you some slack and shoulder part of the repair out of goodwill
  5. Apr 18, 2022 at 7:11 PM
    dimead0zen
    So Cal
    Could the failure be due to the need to re-gear? I have thought about re-gearing but I didn't think it was required for my tire size.
  6. Apr 18, 2022 at 7:33 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Sorry not an expert. I’m not even close . @gearcruncher can answer you . Hope he reads this. He knows
    Junkhead likes this.
  7. Apr 18, 2022 at 9:46 PM
    dimead0zen
    So Cal
    @gearcruncher help!
  8. Apr 19, 2022 at 6:18 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Check your driveshaft u-joints. I had a driveshaft go out on my Subaru some years ago and behaved somewhat like you describe.
    gearcruncher likes this.
  9. Apr 19, 2022 at 12:29 PM
    gearcruncher
    Canadain bumper technician
    I agree that this would be the place to begin diagnsosing . Have you been greasing your driveshaft universal joints at every oil change ?
  10. Apr 20, 2022 at 4:45 PM
    dimead0zen
    So Cal
    Ah, I have never greased the U Joints. How would I know if those are the source of the shudder? Should I grease them and see if it stops?
  11. Apr 20, 2022 at 4:51 PM
    wayne0
    wayne0 Well-Known Member
    Might be too late for that. Could have a bad joint.
  12. Apr 20, 2022 at 5:00 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Crawl under there and try to turn your driveshaft by hand. If there is slop or play, it needs new joints. If tight, move on to something else.
