Bolstering 5100 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VA Tacoma, Mar 16, 2016.
  1. Mar 16, 2016 at 5:11 AM
    VA Tacoma
    VA Tacoma [OP] Well-Known Member
    Frank
    Roanoke, VA
    08 AC 4x4 SR5 off road 4.0 super white
    bone stock
    probably a stupid question but, can I change the height settinng without removing the shocks?
    Thanks
  2. Mar 16, 2016 at 5:13 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
  3. Mar 16, 2016 at 5:20 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Hell no!!! Remember front springs under a shit load of pressure.May cause Death!!!!!!! Take whole unit out take to a spring or shock shop they have a heavy duty wall mounted compressor .they should do it dirt cheap.
  4. Mar 16, 2016 at 5:32 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
  5. Mar 16, 2016 at 5:37 AM
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    And a wise man is a fool if he doesn't have the rite tool. Me.. And a wiser man know what his limits are..me again.I have been doing this shit for a long time.Not the first task you would want to tackle.
  6. Mar 16, 2016 at 5:50 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Not my first rodeo..... I've been working on, driving, and owning 4wds since 1972. I have a shop where I work on 4wds for other folks. There are (literally) thousands of people who regularly post on TW that have installed shocks/springs without a compressor. So easy ANYONE can do it. I guess your "limits" preclude you from the "anyone" category....
  7. Mar 16, 2016 at 5:56 AM
    lawrenccar1
    original post was in reference to removing the shock to adjust clip..
  8. Mar 16, 2016 at 6:03 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Correct. And you do so by loosening tension on coils....re; the video on decompressing/compressing coils without removing them from the truck....Can be (easily) done in 30 minutes per shock. Piece of cake.....
    Do not hate what you do not understand.
  9. Mar 16, 2016 at 6:26 AM
    Pigpen
    Dan
    Northwest Montana
    Bluegrass, you provide many helpful and insightful posts on here. I don't doubt that you are a competent mechanic - far more so than I am. Have you ever adjusted 5100s without removing them? I can see adjusting threaded body coilovers, but the way the spring perch covers the clip on a 5100...I cant see pulling off this feat. The tutorial on decompressing/ compressing a spring with the weight of the vehicle is good info. I've done a few struts this way over the years. I've installed 5100s on 2 vehicles, so I'm no expert. The spring needs to be compressed pretty far, giving several inches of work space, to adjust the 5100.
    Perhaps this is possible, but If the OP has to ask - I'd say no in his case, and in mine too. I'll remove them If I ever feel the need to adjust them.
    Bluegrass, perhaps you could provide a how to thread with pics and/ or video. Thank you.
  10. Mar 16, 2016 at 6:40 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    It seems that what is being referenced is how to remove the tension from the shock without removing it from the truck. So in this case, yes you can reset the height of the 5100 without removing the shock from the truck. The thing that prevents the clip from being changed is the tension on the spring, this method removes the tension prior to removing the shock. I've watched this video many times to prepare for my eventual front suspension upgrade.
  11. Mar 16, 2016 at 6:46 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Short and sweet...Yes I have.
    Next time I do one, I'll get someone to video the process while I do it. I'm most assuredly NOT going to go through the process just to convince someone else of what I already know to be a relatively easy task.
  12. Mar 16, 2016 at 6:52 AM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    Good grief!! I installed them myself using the video on here. I was just asking if it could be done.
    glwood6 and Bluegrass Taco like this.
  13. Mar 16, 2016 at 2:22 PM
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    Most old 4x4 don't have struts.Not til the 90's.Leaf lift straight axle.Lemon to a apple..
  14. Mar 16, 2016 at 2:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  15. Mar 16, 2016 at 6:20 PM
    Pigpen
    Dan
    Northwest Montana
    I'm just asking that you make knowledge available to those of us who don't know. Many of us would appreciate you making that video. Thank you.
  16. Mar 16, 2016 at 8:02 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Did you look at the link in post #4? Not sure why you want a video made personally by Bluegrass Taco when there are several already in existence.
  17. Mar 16, 2016 at 8:31 PM
    Pigpen
    Dan
    Northwest Montana
    My apologies. I thought it was one of the standard videos about installing/ removing struts without a spring compressor.... sorry @Bluegrass Taco. I assumed and made an ass out of me - didn't mean to involve you personally.
  18. Mar 17, 2016 at 3:00 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Excuses excuses excuses.....
    OBTW, try the mid 80's for strut/IFS suspension.....
  19. Mar 17, 2016 at 3:11 AM
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    Not to put any members down but not everyone can just jump in and replace items they never seen or worked on before.This site is for knowledge and Safety!!!!!!!A great man says knowledge is golden.Then anyone can do what they want with it.Not stepping on your toes just want members to have options.
  20. Mar 17, 2016 at 3:23 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    If you would bother to take the time to READ (and comprehend) the OP's statements in this thread, he has already stated he INSTALLED his struts USING THE TECHNIQUE DESCRIBED IN THE VIDEO I POSTED. Not everyone is as dumb as a bag of hammers......Some people are capable of making decisions on their own without having to be saved from themselves. .....I'm trying to provide the OP with the knowledge to do what he inquired about. I'd say THAT would more appropriately fit your "just want members to have options".....
