Bolt dimensions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patr, Feb 21, 2024.
  1. Feb 21, 2024 at 4:05 PM
    patr
    patr [OP] First-time Owner
    2016 Blazing Blue Pearl Tacoma TRD Sport 4x2
    I stripped the threads in the hole when cranking one of the bolts on the 4x4 splash guard after an oil change:
    https://parts.lakelandtoyota.com/p/...Support-Splash-Shield/4070982/5140604020.html
    I was in a rush to get it done so I let it be, but now I want to fix it.
    I've tracked down the bolt:
    https://parts.lakelandtoyota.com/p/__/Bolt-Shield-Front--Rear/4076166/9008011373.html
    Id like to order a tap so that I can redo the threads, but I cant find the dimensions (diameter and pitch) anywhere, does anyone know them?
    I could find my calipers and crawl under there but I feel like the information has to exist somewhere.
    thanks
  2. Feb 21, 2024 at 4:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Probably 8x1.25
    JFriday1 likes this.
  3. Feb 24, 2024 at 3:03 PM
    Devlop
    Devlop Well-Known Member
    Grand Junction, CO
    2023 Tacoma Offroad
    You could take the bolt up to HD or Lowes. They have those panels with the different threaded studs and sleeves that you can test your hardware in. They're in the hardware aisle. It's all labeled.
