Bolt holding the #4 coil pack came loose.
Discussion in '1st Gen. Tacomas (1995-2004)' started by pigger, Nov 21, 2011.
  1. Nov 21, 2011 at 2:53 PM
    pigger
    pigger [OP] Well-Known Member
    Greg
    Applecookie
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, older-than-dirt owner
    I'd been hearing a noise from the engine compartment for a week or two; finally traced it to the bolt that secures the #4 cylinder coil pack (2.7L 4-cyl). It was almost completely unthreaded; ready to fall out.
    I tightened it up again and it seems to be OK; I'm checking it now every once in a while.
    Has anyone else experienced this?
  2. Nov 21, 2011 at 8:33 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Nope, never heard of it. Maybe it was forgotten slightly loose after maintenance?
