Bolt-it-on motorcycle tie down system
Discussion in '3rd Gen. Tacomas (2016-2023)' started by s14brent, Nov 12, 2023.
  1. Nov 12, 2023 at 11:43 AM
    s14brent
    s14brent [OP] Member
    Brent
    Las Vegas
    2021 TRD OR 6MT
    Hey TacomaWorld, i wanted to share a new product from bolt-it-on. I basically was holding off on buying a wheel chock setup for my truck because there wasn't a perfect kit for my needs. You can definitely load up 2 bikes without wheel chocks, i've done it. its just not as worry-free when i have to do 1-4hr drives and especially when navigating on dirt paths.
    A) i didnt want to drill into the composite bed
    B) some of the kits mounted either too high or too long (interfering with tonneau cover mounting - which i need for work) or the wheel chock was so high it would be a bad fit for my mini-motos.
    note: I'm not affiliated with the company and had to pay for this kit. I just am a very happy customer since it fits my needs.
    Basically the kit mounts with d-rings and j-hooks to the forward bed bolts. There is no drilling involved. These use the T55 torx and I recommend using an impact carefully on them - make sure you're using a good socket, god forbid if you strip one of these alum bolts...
    They offer wheel chocks for dirt bikes/street bikes and fat e-bikes. The kit is very easy to customize for different sized setups and its easy to move the quick-ties for preferred strap locations on the cross bar.
    [​IMG] [​IMG]
    I'm not sure if I'm allowed to drop a link (i'll remove it if not allowed) but you can get it here: https://boltiton.com/collections/toyota-trucks
    Big tall dave likes this.
