bolt lock question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by metrick1215, Sep 2, 2015.
  1. Sep 2, 2015 at 5:36 AM
    metrick1215
    metrick1215 [OP] Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    hey guys, needing some advice. I made my dad a fishing rod holder for the rail system for fathers day. He love is, but hes afraid that someone may steal it so he wants a way to lock it down in the rail system. I used the eye bolts, into the square nut things (cant remember what they are called but found them in the rail attachment thread) into the rail system. Trying to decide the best way to do this. Im kind of at a loss, and im sure it could be a simple solution. I also dont want it to be a huge masterlock between the two eyes, unless that is the only option.
    any help would be great! thank you in advance.
  2. Sep 2, 2015 at 5:49 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Even if you figure out a way too lock it, someone can just remove the reel from the rod. Don't take your eyes off your gear.
  3. Sep 2, 2015 at 5:51 AM
    metrick1215
    Habersham GA..
    he wont have the rods in at all times, but wants to have the rod holder in at all times, just for a whim of a trip
  4. Sep 2, 2015 at 6:07 AM
    spitdog
    I see. The only thing I can think off is to drill a hole in the channel that a master lock can fit through.
    That would prevent someone from being able to slide the Tee Nut to the opening and remove the device.
    Or put a stop screw and nut in the channel that would accomplish the same thing.
