Bolt next to spark plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefedTacos, Mar 7, 2024.
  1. Mar 7, 2024 at 9:58 AM
    BeefedTacos
    BeefedTacos [OP] Well-Known Member
    Brian
    North Carolina
    2015 tacoma dcsb SR5 4x4
    None so far
    Made the mistake of loosening. I hand tightened them back. Am I still good?
  2. Mar 7, 2024 at 9:58 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Yeah
  3. Mar 7, 2024 at 9:58 AM
    BeefedTacos
    Brian
    North Carolina
    None so far
    Loosened so much that I could take it almost out before realizing it was the wrong bolt.
  4. Mar 7, 2024 at 10:20 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    There are no torque-sensitive engine bolts on the outside it was probably just a valve cover bolt.
  5. Mar 7, 2024 at 6:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It's fine. It just holds the valve cover down "tighter" at the plug tube.
    The gasket is rubber.
    If you tightened it back down, it will be ok. :thumbsup:
