BOLT on exhaust re-route kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JDKred, Jun 12, 2022.
  1. Jun 13, 2022 at 3:03 PM
    JDKred
    JDKred [OP] Well-Known Member
    JD
    16 MT KDMax Tuned
    I do not want a hang point with the stock exhaust and the funky skids...
    Is it cheaper to simply buy a CBI or other brand skid that will accommodate the stock exhaust, yes..
    But I hate that. Why add an additional hang point?
  2. Jun 13, 2022 at 3:18 PM
    manwithtools
    manwithtools Well-Known Member
    Dan
    So Cal - San Diego
    2021 Cement Gray Off Road
    Fox 2.5's Deaver Stage 2. 5.29's, 285/70/R17 Front E-Locker
    Agreed, re-route and then add the flush skids. It's a silly design decision from a real world point of view. Why make the lowest point of the truck lower than the crossmember when a little effort would have eliminated the problem.
    JDKred[OP] likes this.
  3. Jun 13, 2022 at 5:10 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    An exhaust reroute is a good idea of you drive off-road and want to put armor plates under your truck, just be sure that the new crossover pipe is far enough back away from the plastic dif actuator box as to not melt it. Weld a bolt together union to the new crossover so they can unbolt the pipe to remove it for servicing if needed. I made a shield for mine with aluminum flashing and attached it on the box with steel zip ties. You may also want to extend the existing shielding on the driver’s side further back with the same. Then to finish it all, bob the last bend just after the last hanger and put a spout tip on it.
    Toycoma2021 likes this.
