Bolt On Satoshi!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mudthedoor, Mar 10, 2011.
  1. Mar 10, 2011 at 4:13 PM
    mudthedoor
    mudthedoor [OP] Sconnie
    Alex
    Forestville, WI
    00 4Runner
    There needs to be an initiative taken to create a plastic drop in instert to cover where a grille is cut out to simplify the satoshi process. I would do this myself if I had the resources available to me. I know that there is a market out there for satoshi inserts just from exploring this forum and others like it. Four runner, tacoma, tundra, and even land cruiser owners love the satoshi grille but the difficulty of making one detures most.
    Quesitions & Comments?????????????????????????? :confused:
  2. Mar 10, 2011 at 4:18 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
  3. Mar 10, 2011 at 4:20 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    i think hes talkin about the actual part from the stock grille where u have to either fiberglass repair or cut out another plastic and epoxy to fill in the gap
  4. Mar 10, 2011 at 4:21 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    He makes the mesh, but it still requires body work to install what he makes. Im looking to make somthing that all you do is cut out your current grile and color match it and silp it in and add a grill to eliminate body work. kinda like a cover for where you cut out the grille.
  5. Mar 10, 2011 at 4:22 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Yep... Looking into a local plastic injection moulding company to see if the $$$ is viable... Have a meeting next week.
  6. Mar 10, 2011 at 4:23 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Exactally it would be much easier to do the install this way.
  7. Mar 10, 2011 at 4:23 PM
    yotamikez
    Valrico
    Yeah that would be nice, Im a little weery of cutting up my grill and seeing if I have fiberglass skills myself.
  8. Mar 10, 2011 at 4:23 PM
    TakDwn
    TakDwn Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    If you're looking, I'll sell ya my completed grill. :D
  9. Mar 10, 2011 at 4:24 PM
    AsianAnts
    AnT
    that would be cool... id want to see something like that.. much easier
  10. Mar 10, 2011 at 4:24 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Minor modification may be necessary. :D
    http://www.k2motor.com/hg-cv04tr.html
  11. Mar 10, 2011 at 4:25 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    You are saying like making something that fills the inner part of the grill, so it covers up the area that has been exposed (the one requiring fiberglass and bondo) once you cut the grill?
  12. Mar 10, 2011 at 4:27 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    actually no Fiberglass is needed, just some plastic epoxy and bondo. Easier to do the the fiberglass method.
  13. Mar 10, 2011 at 4:28 PM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    no need for any body work if your grill is flush:D
  14. Mar 10, 2011 at 4:28 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    yep exactly like made out of the same plastic that a after market fender flare would be and should be painted.
  15. Mar 10, 2011 at 4:29 PM
    yotamikez
    Valrico
    Ill have to give it a try, thanks for the tip.
  16. Mar 10, 2011 at 4:31 PM
    epa4wd
    Eduardo
    2019 SR
    I like the idea!
  17. Mar 10, 2011 at 4:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I say just get a grillecraft if you're that concerned about it. 1/2 the fun is doing the work yourself!
  18. Mar 10, 2011 at 4:32 PM
    snowgod06
    Rob
    06 Access Cab
    yea there is a write-up here that shows how to make patch panels out of the crossbars you cut out and then epoxy into place. SUPER EASY
  19. Mar 10, 2011 at 4:32 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Nice you and I think alot alike. You distribute out of a local store right?
  20. Mar 10, 2011 at 6:32 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    This has nothing to do with my job at HD or any vendors I'm affiliated with through work.
    There is a company here in the Philly area that is in the same business development as one of my customers.
    My thought is to create a mold and mass produce a completed satoshi inner section of the grill that can be added to your existing outer surround, then any grill mesh could be used to complete the Mod.
    This would be an excellent alternative for those that lack the time/patience/skill to take on the satoshi project.
    I believe the final result being a manufactured product has the potential to look cleaner and be more durable because it would not need to be painted...
    We'll see...:rolleyes:
