Bolt on slider prep?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MAG GRY TACO15, Dec 30, 2019.
  1. Dec 30, 2019 at 10:13 AM
    MAG GRY TACO15
    MAG GRY TACO15 [OP] Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Do you just bolt them right to the frame or do you rub the areas of contact down with grease, lube, oil, or anti seize before bolting them to the frame for rust preventive measures?
  2. Dec 30, 2019 at 10:17 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    I put anti-seize on mine but we have a lot of wet weather here on the west coast. Gone through two winters now without any issues of rust. Cheep insurance for sure....
    MAG GRY TACO15[OP] likes this.
  3. Dec 31, 2019 at 3:25 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    On initial install, use whatever lube you on the bolts, nuts and washers. Once installed, apply some type of corrosion preventative compound as others are coating their frames to prevent corrosion. After that, I would apply that coating once per year or more often if needed to prevent corrosion between the frame rail and slider.
  4. Dec 31, 2019 at 12:02 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I was just going to rub a light coat of oil over the frame and inside the slider mounting plates. rust isn't a huge issue where I live in GA so it's not that concerning. Just wanted to know if it was a common thing for those with bolt ons
