Bolt on Slider thoughts, CBI, All-Pro, others?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bootboiler, Dec 15, 2011.
  1. Dec 15, 2011 at 6:14 PM
    bootboiler
    bootboiler [OP] Well-Known Member
    Scott
    Softopper, Maggiolina, US Over-Rack, Camberg UCA's, locking tailgate, hid driving lights, ipod connector, B 5100's, Dakar HD Leafs, bud built plates, Relentless rear bumper, sliders with kick, breathers on pumpkins, satochi grill, bed lights, JVC 730BT
    CBI, will cost around $560 with Kick-out, and the current sale. .125 HREW
    All-Pro will cost around $570 Kick-out is standard, (honestly the Kick transission is a bit smoother on these.) .135 HREW
    I want bolt-on, and want to do it myself. Tires will not be greater than 33.
    Any thoughts, suggestions, experiences, or reccomendations?
    Peculiar Travel Suggestions are Dancing Lessons from God.
    Kurt Vonnegut Jr.
  2. Dec 15, 2011 at 6:24 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Of those two I would go with CBI, because they will actually stand up to stuff.
    Any reason you're not looking at Hybrid DOM stuff from Relentless or BAMF? Or having CBI pump some out for you?
  3. Dec 15, 2011 at 6:32 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Funny, that's one (All Pro) I don't like.
    I'm shopping these too and am considering DWreck (no drill and Hi-Lift rated) and 4x Innovations
    Most of the bolt-ons require some drilling.
    Seems like there's currently another thread on this.......
    Kurt Vonnegut Jr.[/QUOTE]
  4. Dec 15, 2011 at 6:34 PM
    jandrews
    I would also advise against a kickout. Your call.
  5. Dec 15, 2011 at 6:36 PM
    jflan
    Vancouver, WA
    Why ?
  6. Dec 15, 2011 at 6:38 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Nobody has mentioned demello yet. They have bolt-ons that do not require drilling. If you want to use a high lift with them, then I think they recommend drilling additional holes. They come with all grade 8 hardware too. I think they are good looking.
  7. Dec 15, 2011 at 6:38 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    Yeah why?
    Kick out are cool.
  8. Dec 15, 2011 at 6:57 PM
    jandrews
    Because I will tell my truck where to go, and when I'm on a tight line where inches matter, I don't want the fucking slider throwing me off because it thought I would rather be a few more inches to whatever side.
    On tight trails kickouts cause more difficulty/complication/problems/tribulations/annoyance/undesirable effects, but not damage, than they save.
    See this line:
    See the tree on the passenger side of the truck? See the rock the driver tire is on? Well, this line is incredibly tight, and the slider grinds along the tree as you pass. There's about 1 inch of clearance. If my slider had had a kickout, it would've thrown me to driver, which would've knocked me off the rock and high centered me on it on the front skid. (I know this because it happened on the three attempts before this picture was taken) The ridge you have to ride next to the tree is about half the width of a 285 tire, which is why the passenger tire appears to be hanging in space.
    This is not the only line I've been on that requires this level of precision. Once again, I want to drive, not the sliders.
  9. Dec 15, 2011 at 7:07 PM
    jflan
    Vancouver, WA
    OIC
    What sliders are those ?
  10. Dec 15, 2011 at 7:14 PM
    jandrews
    ATO hybrid...not really available anymore, although he does sell 4xInnovations setups.
    Hybrid style is significantly stronger and flexes much less because square tube is a lot more rigid than round tube. DOM is stronger than HREW. No kickouts keep you on your line. Weld-on sliders thicken your frame while bolt-ons require drilling holes which create weak spots that get stressed when the slider takes a hit.
    Hence I recommend:
    Weld-on Hybrid sliders, DOM, no kickout, from a quality manufacturer :)
    I like CBI's bolt-ons (if you must...) because they have the most complete bracket out there in their u-shape setup which goes all the way around the frame:
  11. Dec 15, 2011 at 8:13 PM
    pAP
    pAP ==========
    NJ
    11 Tacoma SR5
    ARB locker and OBA, All Pro front & rear bumper, All Pro IFS skid & modified t-case skid, Custom Trans Skid., 4x Innovations sliders, Custom tire carrier/bed bars, Warn Winch, Fox 2.5" Front coilover, Walker Evans 2.5" rear Shock, All pro Leaf, All Pro U-bolt flip, Baja Designs lights, PIA 510 lights, TRD exhaust cut back, Doug Thorley Pipe Bomb
    4x innovations FTMFW. Have them on my rig. You can specify kick out or non kick out.
  12. Dec 17, 2011 at 1:06 PM
    bootboiler
    Scott
    Thanks to all who gave their educated opinions, I am learning, and now have more to consider.
  13. Dec 17, 2011 at 1:06 PM
    bootboiler
    Scott
  14. Dec 17, 2011 at 1:36 PM
    fjfar80
    fjfar80 Well-Known Member
    Mark
    Fairfax, Virginia
    '09 TRD OR DC
    Total Chaos UCA's, King Coilover Front Suspension w/ Remote Reservoir Shocks, King / OME Dakar Rear Suspension with Remote Reservoir Shocks, DO Front Bumper, BruteForce Custom Rear Bumper, Slee Offroad Sliders, Warn w/synthetic line, Softopper, etc.
    Don't forget Slee Offroad's sliders...Christo knows what he is doing. They are expensive but...they're works of art and everything Christo builds is made to work.
  15. Dec 17, 2011 at 1:51 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    How do kick-outs cause more damage then they save? I have yet to see this come into play
  16. Dec 17, 2011 at 1:57 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    I have a set of CBI bolt-ons and they are in my opinion, after a lot of research the best bolt-on option, the u-bracket construction is incredible strong and is a completely drill-less option. Easy to install and strong as hell. I went with the standard one without the kick-out just liked the slim line look better. They line up great and look great with my Bushwacker cut-a-way flares. Expensive but very worth it since I wanted to have a strong bolt on. Just my .02 cents. Good luck with what ever you choose.
  17. Dec 17, 2011 at 1:58 PM
    SoJersey
    SoJersey Man.As.Prescribed
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension ARE Z-Series More coming soon...
    (i like this thread because i too am looking at sliders..)
  18. Dec 17, 2011 at 4:36 PM
    jandrews
    harm =/= damage.
    Different words.
  19. Dec 17, 2011 at 5:48 PM
    jjw1
    Jesse
    same difference
  20. Dec 17, 2011 at 5:51 PM
    jandrews
    No, actually, it's not. Damage is a physical change to the vehicle. Harm can be anything from damage, to throwing you off your line and getting you stuck, to making you too wide to fit between two trees.
    Would the word "problems" have made the concept easier for you to understand?
