bolt on slider ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brutalguyracing, Feb 6, 2010.
  1. Feb 6, 2010 at 7:54 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    i have a set of weld on sliders that i am making bolt on "4 legs per side"
    i have 1/4" x 2" x 4" backing plates to be used
    any advise or tips on bolts to use... and quanity needed per mounting plate
    plates have 4 --3/8" holes on all 4 corners on the backing plates...
  2. Feb 6, 2010 at 8:07 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I would stick with what they already started. Get Grade 8 bolts. Now, you realize you're drilling 32 holes in your frame? I hope you have a powerful drill and top of the line bits because your gonna be in your driveway drilling for like 8 hours.
    I'm shopping for some. I'm just welding them.
  3. Feb 6, 2010 at 8:12 AM
    tonyplanet
    tonyplanet Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    Weld them on. Forget the bolts. Weld ons are stronger. And if you decide to take them off, you won't have holes all over your frame.
