Bolt pattern for rock sliders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sprocket1505, Oct 29, 2019.
  1. Oct 29, 2019 at 2:27 PM
    Sprocket1505
    Sprocket1505 [OP] Well-Known Member
    trying to bolt some custom sliders on a blank frame. How did you guys drill your holes for a 2014 or 15? Please send photos
  2. Oct 31, 2019 at 2:35 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    On my 2010 with BAMF sliders, they utilized existing holes in the frame for the bolts positioned horizontally.
    The holes for the bolts positioned vertically into the frames lower flange would get drilled by the owner.
  3. Oct 31, 2019 at 2:37 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
