Bolt pattern.
Discussion in '5 Lug' started by 808tacomas, Jun 11, 2013.
  1. Jun 11, 2013 at 9:31 PM
    808tacomas
    808tacomas [OP] Well-Known Member
    kingrob
    oahu
    2011 toyota tacoma 4door 4 cyl.
    working on it..need some advice
    Does anyone know the bolt pattern for 11' tacoma double cab 5 lug? Are they the same as the regular 5 lug?
  2. Jun 11, 2013 at 11:37 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I believe that all 5 lugs have the same diameter bolt circle.
    My 2012 STD cab is 5x114.3mm or 5x 4.5"
  3. Jun 12, 2013 at 11:05 PM
    808tacomas
    kingrob
    oahu
    thanz bro
  4. Jun 14, 2013 at 9:43 AM
    tooter
    Greg
    Los Angeles
    You're welcome. :)
    Oddly enough, 5 lug Tacomas have the same bolt circle as Ford Mustangs.
