Bolt question.
Discussion in 'Towing' started by T4RFTMFW, May 29, 2015.
  1. May 29, 2015 at 6:05 PM
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Just noticed that my OEM hitch doesn't have the bolts connecting it to the OEM bumper. Can anybody send me a part number for these bolts? Or a size for them so I can try and find replacements?
    Thanks.
  2. May 29, 2015 at 6:26 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Looks like the part number includes the receiver and the bolts. I think they are m14 and length won't matter as long as they're long enough.
  3. May 29, 2015 at 6:36 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  4. May 29, 2015 at 7:12 PM
    T4RFTMFW
    Thank you sir. :bowdown:
  5. May 30, 2015 at 3:37 PM
    KenLyns
    Belly of the Beast
    Come 2016 they'll probably re-use the same graphic lol.
  6. May 30, 2015 at 3:41 PM
    T4RFTMFW
  7. Jun 2, 2015 at 10:08 PM
    Davidski
    Davidski Active Member
    David
    Northern Cal
    15 TRD OR 4x4 Silver Access Cab
    Ultra-gauge, extra bed D-rings, pop-n-lock, backflip tonneau cover, L-Track bed tie downs, Tech-Deck, mirror riser, and Relentless Fab Tailgate plate
    I wonder why those bolts are there between the OEM bumper and the OEM hitch.
    On my Gen-1 there are just bolts on the frame to the hitch. No connection between the receiver hitch and bumper. On the Gen-2 there are double the number of bolts on the frame to the hitch. The load from the hitch is supposed to be transferred to the frame with a receiver hitch. You may ask why am I telling you this.
    Back up a couple of months ago when I pulled my boat/trailer the first time with my new 2nd gen Tacoma I had a surprise at the end of the day. The boat and trailer is about 3500-4000lbs. Tounge weight is 275lbs. Well under the maximum tow limits and tounge weight. After I parked the boat/trailer and put the truck back into the garage I noticed the bumper was drooping (I should of taken a pic, my bad). The bumper was not bent. The conclusion I came to was the receiver hitch to frame was not tightened to specs at the factory.
    I loosened all bolts between the frame and receiver hitch, and removed the two bolts between the bumper and receiver hitch. Repositioned the bumper to where was supposed to be. I have not installed the vertical bumper to hitch bolts yet. Without those bolts attached, the hitch is not mechanically tied to the bumper. I wanted to tow some with only the load going to the frame without a chance of bending the bumper. So far no more movement of the receiver hitch after towing. I will eventually replace those bumper to receiver hitch bolts, but I am not in a hurry.
    Back to my Gen-1 that has no coupling between the receiver hitch and the bumper. Are those bumper to hitch bolts needed?
