bolt removal help
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Jul 9, 2010.
  1. Jul 9, 2010 at 11:36 AM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    I was replacing my tailgate cables today and the first one's screw came off just fine. I thew on the cable, screwed it back on and was good to go. Then i tried replacing the other side but that screw isn't budging. Being the dumbass that I am I lost my cool and ended up rounding it out pretty badly. Any suggestions as to how I get a rounded out screw out?
  2. Jul 9, 2010 at 11:51 AM
    Stu
    Stu Well-Known Member
    G'Ville, NV
    Taco TRD OR
    Not much yet, got a pretty good sound system w/ my custom sub box. Plan on adding more lights & a tool box.
    I'm not familiar w/ that screw, but...
    You're going to have to replace the scew anyways, so I'd go after it with a hammer & cheisel (sp?)
    Just cheisel it leftie-loosie! till it becomes easy.
  3. Jul 9, 2010 at 12:02 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2006 Infiniti M35x
    Could you get a reverse drill bit and get it out? As the reverse bit tightens (i.e. goes into the screw), it should work to loosen the screw. I had to do that with one of the allen screws on the bed rails that was put on entirely too tight by someone at the factory when I but on my tonneau.
  4. Jul 9, 2010 at 12:07 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    x2.
    You might have to remove the bolt head through cutting, drilling, and chiseling. Often when you remove the head of the bolt, the tension on the threads that's keeping it tight will be relieved and you'll be able to back it out using the method above.
    If that doesn't help, then the bolt's probably rusted in place. In that case you're looking at drilling the whole thing out, re-tapping the hole, and installing the new bolt.
    It's time consuming but we've all been there.
  5. Jul 9, 2010 at 12:10 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    what he said^^^^^^^^^^^^^^
  6. Jul 9, 2010 at 2:39 PM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    I bought a cheap set of Ease-Outs at Lowe's a few month ago. They work well. I think the brand name was Grab Its.
    You take one side and drill into the top of the bolt. Once you drill so far down, flip the bit over and drill into the bolt with it by drilling left. So far it has work well for me.
    If it is rusty get some Kroll Oil and let it soak for awhile. If Kroll Oil is not available get some PB Blaster.
  7. Jul 9, 2010 at 2:46 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    What they all said! ^^^ ;)
  8. Jul 9, 2010 at 2:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    either ez outs....or use a pair of vise grips to break the bolt loose and then replace it.
  9. Jul 9, 2010 at 5:48 PM
    toyotadan
    toyotadan Member
    washington
    98 4x4
    i couldn't find the change either
