Bolt Size to Use with Puller, to Remove Crankshaft Timing Sprocket on 3.4L V6 5VZ-FE?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mltitlntd, Feb 1, 2017.
  1. Feb 1, 2017 at 2:51 PM
    mltitlntd
    mltitlntd [OP] Well-Known Member
    Steven
    New Orleans, La
    99 Tacoma 3.4 V6 4WD SR5
    None
    Not the harmonic balancer/pulley, but the timing sprocket on the crank
    See the threaded hole in the pic below? There's two of em. They're smaller than the ones on the Harmonic Balancer
    That's not mine, BTW. I broke mine, but still need to get it off.
    Thanks for any information!
  2. Feb 1, 2017 at 3:53 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    There either M8x1.25 or M10x1.25
    If I had the engine apart I could tell
  3. Feb 1, 2017 at 4:03 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Key-Rei and cruiserguy like this.
  4. Feb 1, 2017 at 4:12 PM
    mltitlntd
    Steven
    New Orleans, La
    None
  5. Feb 1, 2017 at 5:09 PM
    Dirty Pool
    99 XCAB V6 MT TRD
  6. Feb 1, 2017 at 5:24 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Key-Rei likes this.
  7. Feb 1, 2017 at 5:38 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    One observes/remembers selectively plus I participated in that thread and my crank pulley holding tool came with the bolts for the timing gear. Don't ask me my land line phone number or my anniversary.
    Key-Rei, SR-71A and burntkat like this.
  8. Feb 1, 2017 at 5:46 PM
    cruiserguy
    Elijah
    SEKS
    Lolol, my mind works very similarly.
  9. Feb 1, 2017 at 6:33 PM
    mltitlntd
    Steven
    New Orleans, La
    None
    I second that emotion, Cruiser! I searched for quite a while today and came up with a number of relevant threads, but none that mentioned the bolt size. Wish I'd have found that, before breaking off a chunk of the gear flange, with the teeth that the CPS senses. Glad to have that info now though. Thanks D.P.
    The damned thing is STILL on there, soaking in PBB. I even tried heating with a propane torch and prying from behind, which is when I finally broke it. The stealer's gonna get about $75 from me tomorrow, and the government will get another $7 or so...
    I have a steering wheel puller, like the one pictured in the referenced thread, but maybe I should borrow a puller from a parts store? I don't guess they would have the correct-sized bolts??
    All of this trouble is because of this
    https://www.tacomaworld.com/threads...6-engine-came-on-fast-opinions-please.471995/
    I'm wondering if the leaking oil has baked onto the crank, gluing the sprocket on. Hoping like H-E double-hockey sticks it the seal and not the oil pump leaking. I have a 4WD and DO NOT want to drop the oil pan!
    cruiserguy[QUOTED] likes this.
  10. Feb 1, 2017 at 6:44 PM
    mltitlntd
    Steven
    New Orleans, La
    None
    Ahh... I just realized you guys have been there all along :)
    cruiserguy likes this.
  11. Feb 1, 2017 at 6:47 PM
    cruiserguy
    Elijah
    SEKS
    Sorry man, that wasn't a dig at you. More of a little bit of a joke with Dirty.
    I can tell you've done your homework, brother. And I, for one, appreciate the detail you put into your posts. Makes it much easier on trying to help, instead of asking the standard 20 questions at the beginning of most problem threads. I wish I could be of help for you. And the reason I 'like' tons of dirty's posts is that it makes it much easier to find them later, to use as troubleshooting guides. The majority of his posts have a grip of info in them. So if I liked a post of his above that could've been taken the wrong way, it prolly had some good info.
    And if I wrote all this and you had never taken it the wrong way anyways...... Well.... Damn.
  12. Feb 1, 2017 at 6:52 PM
    mltitlntd
    Steven
    New Orleans, La
    None
    Not at all, Wyoming. I don't even know what you're talking about, other than that Dirty Pool seems to have a ton of useful knowledge.
    Seriously, if you did or said something I may oughta have been offended by, I missed it. I appreciate help, wherever I can get it. I should probably spend more time on here, so I can share a bit of the knowledge I've gained, working on this puppy.
  13. Feb 1, 2017 at 9:16 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I hope you can get it off with the puller. It's lucky these gears have the holes to use a puller with.
    If it didn't have the holes I was going to say you need at least a 2 foot pry bar to get the leverage to pry it off, and you need to get the pry bar down far enough to contact the crankshaft. What size/type of tool were you using to try to pry it when it broke?
  14. Feb 2, 2017 at 1:14 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Wow I just can`t believe they are only M6x1.0 .
    All I can hope is the threads go through the gear.
    Use the longest bolts that don`t bottom out
    I just cringe putting enough pressure to break that loose on those M6 bolts
    Best of luck
  15. Feb 2, 2017 at 5:02 AM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    Why not have the bolts bottom out? Seems you'd want them threaded as far as possible so the threads don't strip. Pulling evenly with the puller should do the trick.
    I'm curious why the seal is leaking so bad once the gear is removed. Is the seal damaged or maybe a scratch on the crankshaft damaging the seal?
  16. Feb 2, 2017 at 6:30 AM
    mltitlntd
    Steven
    New Orleans, La
    None
  17. Feb 2, 2017 at 6:34 AM
    mltitlntd
    Steven
    New Orleans, La
    None
    It's a pry bar. Decent size. Not sure it went all the way to the crank before it broke, but goes there now! In addition to TRYING not to break the sprocket, I had to keep in mind I was praying against the aluminum oil pump body.
    By the way, I see I responded to Wyoming earlier, when I should have addressed my comment to cruiser
  18. Feb 2, 2017 at 6:38 AM
    mltitlntd
    Steven
    New Orleans, La
    None
    The threaded holes are only a tad over 1/4" deep, so yeah, not much of a purchase on this stuck sprocket.
    I'm not sure it's the seal leaking, but hoping it's the seal, as opposed to the oil pump o-ring, or gasket or whatever. I hope to be able to tell, when and IF I get the gear off.
  19. Feb 2, 2017 at 10:01 AM
    mltitlntd
    Steven
    New Orleans, La
    None
    OK, I got it off, but it kicked and screamed all of the way.
    I cleaned up the crank with steel wool and sandpaper. It looks like its the main seal. Either I didn't seat the it properly before, or it worked it's away out on the bottom.
    Assuming I have no major issues swapping the seal, do you recommend using anitseize or something on the sprocket and harmonic balancer? I'll clean up the inside of the HB as well.
  20. Feb 2, 2017 at 10:05 AM
    mltitlntd
    Steven
    New Orleans, La
    None
    Meant to post this in the last reply
    I can confirm M6 x 1.0 is the bolt size for the threaded holes in the crankshaft timing pulley / gear / sprocket.
    1997tacomav6 and cruiserguy like this.
