Bolt specs please - Rear bumper mounts (to frame)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lizard_Town, Nov 2, 2023.
  1. Nov 2, 2023 at 9:57 AM
    Lizard_Town
    Lizard_Town [OP] Member
    2000 Tacoma Xtra 5ze
    Hello all !
    I am replacing my stock taco chrome rear bumper with a high clearance bumper.
    The 4 bolts (and 2 nuts) that mount the arms to the frame - does anyone know what size these are ? and what the torque spec ?
    so far , the consensus I have found on torque is 59ft/lbs
    I should replace these with Grade 8 , yes ?
    M?
    Thanks !
  2. Nov 2, 2023 at 10:43 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    https://www.tacomaworld.com/threads/bolt-part-number.812225/
  3. Nov 2, 2023 at 11:26 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If I was really stuck I have used 7/16" out of the bolt bin.
    If you pull on the bumper and do not have a hitch and can not find Metric Hardware grade 8 will work fine.
  4. Nov 2, 2023 at 12:33 PM
    Lizard_Town
    If they come out clean, I suppose I can re-use them, but they are over 20yrs old and a bit rusty. I would rather put in some bombproof new hardware, the new off-road bumper has a built in hitch receiver so I will be using this to tow or cargo.
  5. Nov 2, 2023 at 1:03 PM
    Bivouac
    Measure the ID of the hole Find bolts that have a snug fit get nuts flat washers and lock washers and your Good to go.
    If you see Winter Chemicals Never Seize is your friend.
