bolt stripped?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowyer2002, Jul 5, 2012.
  1. Jul 5, 2012 at 10:00 AM
    bowyer2002
    bowyer2002 [OP] always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    While installing a new front driver's side axle, I think I may have stripped one of the four bolts that hold the lower ball joint to the steering knuckle! (I was torquing them to 60ft/lbs)
    I have already seen the damage when the lower ball joint goes out and DO NOT want to experience that!
    Where can I get a new steering knuckle?
    Any suggestions are welcome!
  2. Jul 5, 2012 at 4:38 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    did you try putting one of the other bolts in the "stripped" hole and see if it tightens? You may have just messed up the bolt. I have done that one, I always keep a few extra around.
  3. Jul 5, 2012 at 5:03 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    New bolts are a buck fiddy from toyota.
  4. Jul 5, 2012 at 8:31 PM
    bowyer2002
    NE Missouri
    Pay attention boys & girls.
    When you don't put the right bolt into the right hole it costs you about 2 hours of work to resolve the problem.:mad:
    There IS a DIFFERENCE in the lower steering knuckle bolt lengths;
    You must put the LONG bolts into the holes closest to the rotor and the SHORT bolts into the remaining two inboard holes.
    OTHERWISE there is not enough thread engagement and the bolt strips.
    (Which is OK since the bolts are a few bucks and a NEW steering knuckle is over $300!)
    I had to clean out the threads in the knuckle (where the bolt stripped) with a tap M10 x 1.25.
    After that, everything went right back together - with red locktite going on the new bolts too.
    Thanks for the input, I'm back on the road again!
  5. Jul 6, 2012 at 1:17 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    :eek:
    I'd have used blue. At the proper torque, neither is needed (and the lubrication provided by the Loctite affected your torque readings, you are actually higher than spec).
    Problem with red is it's a complete bitch to clean out of the threads during reassembly, and it's going to take significantly more than 60ft/lbs to break those bolts free next time.
  6. Jul 6, 2012 at 2:55 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    The first bolts that came from the factory on the LBJ were coated with a green thread locker equivalent to blue locktite.
    I use it every time I have that front end apart even out on the trail.
    Red Locktite is a tad bit overboard.
  7. Jul 6, 2012 at 5:15 AM
    bowyer2002
    NE Missouri
    Red may be overboard, I agree but, I hope this is not a part that I 'regularly' disassemble.
    So, the overkill is okay with me.
  8. Jul 6, 2012 at 7:31 AM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I stripped the same bolts when doing my CV's...they are actually horrible to thread back in.
    But, when I replaced my lower ball joints recently with Moog versions, I noticed that the supplied bolts were all the same length??
  9. Jul 6, 2012 at 7:34 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    glad you got it fixed, I hope you're ready to bust out the torch next time those bolts have to come out:eek:
  10. Jul 6, 2012 at 7:42 AM
    bowyer2002
    NE Missouri
    I'm no stranger to using the torch when necessary.:D
  11. Jul 6, 2012 at 7:45 AM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Eh, well when you wheel as hard as I do, and you expect to break the CV's, you don't want to make the job any harder. ;)
    That's fine. They're probably the shorter length. There's probably only a 5mm difference between the long ones and the short ones. Still plenty of thread engagement for the inner two. Don't sweat it.
  12. Jan 17, 2016 at 3:13 PM
    louied817
    louied817 Well-Known Member
    Guys, same issue here. i went to tighten one of the bolts - one of the two that don't come out the other end - and it stripped - last 1/4 of an inch or so of the bolt. so what are my options? can i use the M10 x 1.25 tap option to clean out the threads? not sure what exactly happened since it appears to have stripped inside the end of the knuckle hole...not the beginning.
    should have left it as is i guess. was trying to torque everything and just kept wrenching like an idiot!!
  13. Jan 17, 2016 at 3:14 PM
    louied817
    also, bolts were all the same length for what its worth.
  14. Jan 17, 2016 at 3:33 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    All my bolts were same length
  15. Jan 17, 2016 at 5:29 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've always used red. It's not that hard to get out. Don't even need a torch.
    bowyer2002[OP] likes this.
