Boltover/overlay grille help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, Mar 9, 2009.
  1. Mar 9, 2009 at 1:48 PM
    BreezyTaco
    BreezyTaco [OP] Well-Known Member
    Corpus Christi, TX
    Pioneer Indash GPS, JL Audio Speakers, FM Alarm, Euro Tail lights, Blue Dash Lights, Trailor Hitch, Painted Fiberglass A.R.E. Tonneau Cover
    I was wanting some help on how the installation works on a boltover/overlay grille. If anyone has any advice please send it my way, now I'm not talking that putco chrome overlay on the black grille, but an actual mesh grille, and if you have a great looking grille go ahead and post it so I can get an idea of what I want. Thanks
  2. Mar 15, 2009 at 10:45 AM
    BlueTRD09
    BlueTRD09 Member
    Jimmy
    Southern NJ... at da beach
    09 Tacoma TRD
    Eagle Eye Projector Halo Headlights, Grillcraft MX Black Mesh Grille, OME 2.5" Tacoma Lift
    I just installed my Grillcraft MX series grille last night... here are pics from after the install. If you need installation help, let me know and I will gladly help you out.
  3. Mar 15, 2009 at 10:56 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Are you going to paint the radiator fins black?
  4. Mar 15, 2009 at 11:00 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Now I may have read this wrong, but do you just want a bolt over and do no cutting, or are you willing to cut the center section out.
    In that case there are a number of choices I went this route but many people went others and I am sure they will chime in.
  5. Mar 15, 2009 at 11:18 AM
    BlueTRD09
    BlueTRD09 Member
    Jimmy
    09 Tacoma TRD
    I was thinking about painting the fins black, but then I looked a little further, and if I'm not mistaken that is the air conditioning plant's condenser. I would want to remove it to paint it and then I would need a recovery system and more refrigerant, which is a pretty big project.
  6. Mar 15, 2009 at 11:49 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Use a couple of paper shopping bags and a rattle can...real short light shots...lots of a coats and it'll be fine. Do it in a garage if you can to minimize wind. (I sprayed mine with flat black radiator paint)
  7. Mar 15, 2009 at 4:54 PM
    BreezyTaco
    Corpus Christi, TX
    Blue: How do those headlights work for you? I wanted to install some but I heard that they were melting the plastic??? Any word on that. Did you just cut out the OEM grille part, and then put in the new one?
  8. Mar 15, 2009 at 9:27 PM
    BlueTRD09
    BlueTRD09 Member
    Jimmy
    09 Tacoma TRD
    The headlights are working out well so far... little bit of fogging, but no melting going on. The bulbs are whatever came standard in the headlights which I believe are not HID's. As for the grille... I had to cut out the plastic grille insert. I used a Sawzall and a Dremel tool to cut out the factory grille. I then taped up the remainder of the grille and painted the gray inside of the grille with some black spray paint. The instructions that came with the Grillcraft grille were pretty easy to follow and included pictures. You will get out of the project what you put into it. Hope this helps
  9. Mar 16, 2009 at 5:04 PM
    BreezyTaco
    Corpus Christi, TX
    Most surely does. I think the grille I found on eBay isnt a grillcraft, I have the instructions to it, and it looks like it will be a lot easier once I have the product in front of me, but for now I'm working on getting side steps, and color matching door handles.
