Bolts For UCAs...
Discussion in 'Suspension' started by jmed99, May 17, 2010.
  1. May 17, 2010 at 11:30 AM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I'm thinking about cutting the stock bolts and putting new ones in...I heard it was easier. Does anyone have a part number so I can order those? The dealership is waaay out of the way for me so I prefer ordering them.
    Thanks! :D
  2. May 17, 2010 at 1:18 PM
    225nontypical
    225nontypical ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    i just replaced my UCA getting the stock ones out was not that hard. i had both sides done in 2 1/2 hour. yes i had to bend the metal a little but i bent it right back and with the mud curtains on you can not even see the metal i bent anyway. even if you could you would not be able to tell.
  3. May 17, 2010 at 1:20 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Not sure why on earth you would want to do that. What's the possible gains by replacing a bolt?
  4. May 17, 2010 at 1:24 PM
    weiser5150
    weiser5150 Stickers and new floormats arent Mods
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Bilsteins all around,Front set at 2.5",Toytec AAL,LR UCAs,18x9 ATX Thugs,275/70R18 Toyo MT's,Relentless Fab Sliders,Satoshi Grill with TRD emblem and Hella Black Magic's converted to HID behind it.
    they cut them so they dont have to fight with them and bend the fender well to get them out.
  5. May 17, 2010 at 1:26 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    The UCA bolts are installed at the factory with the body off the truck. With the body on, it's easier to install/remove them from the rear as opposed to the front.
  6. May 17, 2010 at 2:34 PM
    jmed99
    SC
  7. May 17, 2010 at 3:14 PM
    mjp2
    NJ
    Call up a dealership and have 'em deliver.
  8. May 17, 2010 at 3:58 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    We tried cutting them once. I'm not sure if I just had a lousy sawzall blade, but it was not cutting them worth a shit. I chewed the teeth off of 3 blades before we gave up. we ended up just removing them the old way. I have it down to a science now and can get them out pretty easily.
  9. May 17, 2010 at 6:32 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    ...you still have to reinstall them if you get new ones....remember that...:D
  10. May 17, 2010 at 8:06 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    You reinstall them backwards from the factory installed direction, back to front, easy.
    I cut mine off with a hacksaw in 10 min... I recommend a sawzall. Toyota stealer charged me $15 a bolt but at that point what's another $30 to do it right.
    Bending the pinch-weld is fine but my truck is in new condition, no need to intentionally dent it... even if you can't see it.
  11. May 17, 2010 at 8:09 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    but your NOT doing it right, your installing the opposite of the OEM direction! :rolleyes:
    j/k man!:D
  12. May 17, 2010 at 8:10 PM
    splitbolt
    splitbolt Well-Known Member
    Arkansas
    2016 TRD OFFROAD DCSB MGM
    Bolt 90105-A0095
    Nut 90080-17208
  13. May 17, 2010 at 10:17 PM
    nvdeserted
    Reno, NV
    Yosh2000
    I agree, but the bolt acts more as a stationary axle for the UCA than it does as a fastener, it won't change any relevant strength characteristics if the nut is on the front or the back. I think that was just a manufacturing/assembly efficiency call for whatever reason
    I wonder what the recommended procedure is in some Toyota manual somewhere..... Bend pw? Cut bolt? Remove body?
  14. May 17, 2010 at 10:26 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ that would be interesting to see what the manual says!
    one specific reason that i can think of as to why the bolt is placed the way it is, is that if the nut was to come off, there is no way for the bolt to slide out mounted the OEM way, therefore ensure that the UCA stays engaged to the truck.
    there is a chance that if you lost the nut w/ the bolt mounted backwards, that it could slide out and the UCA could become disengaged from the truck. yes, call me a freak for thinking that, it will most likely never, ever happen, but it is possible if you mount it that way.
    note that the nut is on the bottom of the driver and passenger side...i blame my engineering education for thinking this way!
  15. May 18, 2010 at 6:07 PM
    nvdeserted
    Reno, NV
    Good point Yosh. That's why I locktited mine. But you might be on to something about fail-safe UCA bolts.
    Now this is gonna bug me. Might have to stop by the dealer and see if a tech will let me check their book on the replacement procedure.
  16. May 18, 2010 at 6:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    http://ncttora.com/fsm/05+/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/03900710.pdf
    I have a buddy who is an Ex Toyota mech., and he said that the procedure is to bend the pinch weld, then remove the bolt. Reinstal the same direction, then bend the pinch weld back into place.
  17. Mar 7, 2012 at 9:53 PM
    backcountryj
    backcountryj Well-Known Member
    Jonathan
    GA
    2017 QS DCSB TRD OR 4wd
  18. Mar 8, 2012 at 5:13 AM
    Swampmonkey
    Swampmonkey Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    I wouldn't cut. I was able to put my passenger side bolt in the opposite way but had to put drivers side back in the same way because of the lines on the back side of fender well. So you might as well just use the ones you have. Hope that makes sense.
  19. Mar 8, 2012 at 2:00 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    I purchased the bolts to do this, but once I got in there to do it, it took all of 2 minutes to bend the metal out of the way. Installed, and bent the matal back and you can't even tell it was done.
