Bolts\studs sticking up behind air intake hose??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JOSHSHIZ4, Jul 26, 2012.
  1. Jul 26, 2012 at 11:33 PM
    JOSHSHIZ4
    JOSHSHIZ4 [OP] Member
    Josh
    Santa Clarita
    2011 TRD off road 4x4
    Nothing yet!
    Hey guys i have a 2011 trd off road tacoma 6speed manual 4x4. i was looking under the hood and right behind the air intake boot there are 3 studs sticking up looking like the the bolts for the top of your shock tower but they are located farther back from where the shocks mount. does anyone know what they are and if they are for like an accessory or something. It is on the fender well under the hood behind the air intake close to the firewall.
    thanks for the help
  2. Jul 26, 2012 at 11:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    ABS Brake Controller System.
  3. Jul 27, 2012 at 9:41 PM
    JOSHSHIZ4
    Josh
    Santa Clarita
    Nothing yet!
    No it's on the passenger side behind the cold air intake tube ontop of the fender under the hood, it almost looks like something is missing. All it is is 3 studs sticking about 3 inches up in like a triangle pattern.
  4. Jul 27, 2012 at 10:02 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    Lol my 2010 has the same thing. IDK what it's for looks like a great spot for a second battery though.
  5. Jul 27, 2012 at 10:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yes.
    Some models have the ABS controller located there.
    Others have it built into the master cylinder.
    I believe the TRD offroad has it built into the master and the power brake system is hydraulic, no vacuum "dome" behind the master.
  6. Jul 28, 2012 at 5:36 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    RICH, CHRISTIAN YOU ARE BOTH WRONG! HIS ABS HAS FALLEN OFF!!! DO NOT DRIVE! YOUR ABS FELL OFF AND YOU NEED TO FIND IT AND PUT IT BACK ON BEFORE YOU ATTEMPT TO DRIVE THE TRUCK ANYWHERE.
    It's been a weird night and morning, they're correct ^ I'm just joking, it really depends on the year though, my TRD has ABS right there and I have a vacuum booster
  7. Jul 28, 2012 at 9:15 AM
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    On my 2008 Taco the ABS was mounted there. On my 2012 it's on the left and attached to the master cylinder.
