bolts that hold on skid plate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NWtacoma, Jan 25, 2011.
  1. Jan 25, 2011 at 4:27 PM
    NWtacoma
    NWtacoma [OP] Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    what size wrench will i need to remove them? gonna go put a trd skid on. thx
  2. Jan 25, 2011 at 4:28 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    I want to say 12mm...either than or 14.
  3. Jan 25, 2011 at 4:29 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    sweet thanks.
  4. Jan 25, 2011 at 4:43 PM
    jandrews
    :anonymous:
  5. Jan 25, 2011 at 5:08 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    yep the're 12mm.
    i need my skinny roomate though, i couldnt fit under my truck so i couldnt get it to line up straight lol
  6. Jan 25, 2011 at 5:56 PM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I used a 12mm socket and a 8mm 1.25 tap and die to clean up threads but I have a 2.7 if that makes any difference.
  7. Jan 25, 2011 at 10:17 PM
    sly
    sly Well-Known Member
    Calgary, AB, Canada
    05 SWB TRD Sport
    wow, are you that lazy? grab a few diff sized, 12-14, and find out which one fits. you probably spent more time typing on here than it would have taken to find out for yourself.
  8. Jan 25, 2011 at 11:29 PM
    RichardTRD
    RichardTRD Well-Known Member
    Richard
    Oregon City Oregon
    2011 Tacoma TRD OFF ROAD 4X4
    12mm for both front two and rear two. I just purchased the skid plate from a Toyota dealership and they informed that the skid plate was not TRD but rather just a toyota "upgraded" skid plate. Just wanted to pass that along..unless there's another skid plate that is infact TRD.
    The skid plate took about 10 minutes if that to install. Hardest part being to get those two front bolts started with the factory skid plate aligned.
  9. Jan 25, 2011 at 11:33 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Its 12mm like every one else has said. Its a real bitch to put on. To make it a little easier, take a screw driver and line it up then put the bolt in (for the front 2), for the back 2 those go in first then slide the silver one on then the front two bolt go in.
  10. Jan 26, 2011 at 2:32 AM
    george3
    new jersey
    tacoma
    Mine wasn't hard at all. If I remember correctly it as tabs that slide in slits in front and hold it in place so you can hold it with one hand and start a bolt with the other - but then again I could be completely wrong - it's been a while.
