Bolts that secure bed - Need specs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jckid, Jan 7, 2009.
  1. Jan 7, 2009 at 4:30 PM
    jckid
    jckid [OP] Member
    CA
    09 Black TRD PreRunner Access Cab
    I may need to replace two of the bolts that secure the bed to the frame, because I'm looking at using the two front ones to mount a custom item. The existing bolts may be a bit short. Does anyone know the specs on the existing bolts? All I know is that they require a 55 Torx to remove, but I would need complete specs in order to locate longer bolts.
  2. Jan 7, 2009 at 5:11 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    your best bet would be to remove 1 bolt and take it to Lowes... find a nut that threads on and then you'll have the bolt specs.
    What are ya going to mount?
  3. Jan 7, 2009 at 5:22 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
  4. Jan 7, 2009 at 5:31 PM
    Delmarva
    Tucson, AZ
  5. Jan 7, 2009 at 5:38 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  6. Jan 7, 2009 at 5:53 PM
    jflan
    Vancouver, WA
    If it ain't available at a reputable "fastener supply house" (or their sources), it ain't available :D
    It may be possible to get them from your Toyota dealer (read spendy) and if they don't have them, then see if they can check with their nearest Toyota Logistic Services depot for that fastener.
    That's pretty much it.
  7. Jan 7, 2009 at 6:39 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^I'd say it's almost a full inch.
    I'd make a bet on that one, actually. These are specialized bolts and the only place, after looking for a week online and off, was at the dealership and they had to be ordered.
  8. Jan 7, 2009 at 7:20 PM
    jflan
    Vancouver, WA
    Now that's why I inserted the CYA clause.....Toyota Logistics Services :D
  9. Jan 7, 2009 at 7:28 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Go to a good hardware store, like ACE or True Value. Lowes and Home Repo doesnt carry enough of anything metric. You probably wont get a torx head but whatever you get make sure it's grade 8, that is the strength of the bolt, grade eight is mucho grande.
  10. Jan 7, 2009 at 7:45 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    I'll bet you tell all the girls that!! :D
    Sorry I had to...
    Now to add a useful remark to the thread!
    You can take in your old one to a person who has a metal lathe and they can build you one! May have a custom head on it.. (not a Torqx but it would work?)
    My Dad just sold his lathe last weekend so I can't help out... someone on here might be able to fabricate one?
  11. Jan 7, 2009 at 8:11 PM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    very good information, or if you have a tap and die set, measure it out, and order them online.
  12. Jan 7, 2009 at 9:46 PM
    nighthawk87
    nighthawk87 Well-Known Member
    check with the one of members who recently mounted a spare tire in the bed...probably had to do something similar...
  13. Jan 7, 2009 at 9:53 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    I'd go with this... Try am ACE hardware or something....
    Worst case you don't end up with a Torx head.... just make sure you get a grade 8 bolt or better...
  14. Jan 7, 2009 at 10:15 PM
    red taco
    red taco Well-Known Member
    Cole
    La Verne, CA
    07 PreRunner Impulse Red Pearl
    Theirs did not use the factor bed mounting bolts as far as I know. I remember something being said about drilling holes and a custom bottom plate to keep them from pulling through the bed.
  15. Jan 8, 2009 at 4:37 AM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    Yep, just a top and bottom plate for my bed mount tire carrier, nothing to do with the bed bolts. Like Wilson said, there's almost a full inch of thread before they engage. As I recall, those bolts have a very fine metric thread, not a coarse thread, and I'd have to guess it would be very difficult find something to work with. They are only threaded about half the length or so as I remember it.
    x2 on what Johnson said. Just take 1 bolt to a local metal shop and see if they can order an oversized length and diameter grade 8 bolt and turn it down to size and match the thread for what your project requires? Or at the least, maybe they can tell you the thread so you can search online?
    We all want to know, what is your custom item?? :D
  16. Jan 8, 2009 at 11:23 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    you will be looking for a 10.9 mark on top of the bolt for grade 8 strength...obviously, the torx head bolt won't have this designation cause there's a big hole in it. a standard hex head cap screw of metric variety will be marked 8.8 or 10.9. SAE grade bolts 8 should have 5 hash marks around the head pointing in, grade 5 will have three. what you need to find these bolts is the diameter and the thread pitch. it'll be like: 16mmx1.5x50mm. (example) the thread pitch is the crucial (middle)number. the first number is your diameter and the last is the length. there are several pitches for each size of metric fastener...(1.0, 1.5, 1.75 and 2.0 i think) these numbers refer to the number of threads ^^^ per 1 millimeter of length.
    if you have a NAPA in your area, check with them...they may be able to identify it for you, even if they don't have it.
    does the bolt thread into a mounted nut (on the frame) or just pass through the bed and frame then secure with a nut? (have never looked at mine, though i will face this dilemma in the future when i put my "custom" stuff in.) :D hope this helps and be sure to report back if you figure it out.
  17. Jan 8, 2009 at 11:24 AM
    Delmarva
    Tucson, AZ
    I think it threads into the frame, hence the concern with trying to find new ones.
  18. Jan 8, 2009 at 6:48 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Yes, it threads directly into the frame.
