bonehead mistake with 4X4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tombiosis, Sep 17, 2011.
  1. Sep 18, 2011 at 8:25 AM
    #41
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You can sig part of it. It's only two sentences long.
  2. Sep 18, 2011 at 9:00 AM
    #42
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    My bad. Can't lose the picture. That thing is badass.
  3. Sep 18, 2011 at 9:04 AM
    #43
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    sometimes i take mine out of 4wd drive while stationary, and when i go to take off i hear a clunk. nbd
  4. Sep 18, 2011 at 4:15 PM
    #44
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    248 thousand miles on my 97 Taco all most all winter in 4 wheel drive because in iffy weather I never knew if it was wet or frozen it's damn dark at 5 AM same thing with my 94 Taco and my wife's 88 Jeep only reason I took it out was to save fuel when the roads were dry but you are right I did have to replace the rear U joint at 209,000 miles in the 97 and a front axle joint in the Jeep at 108 thousand sold the 94 with 156K never did any thing to it. I'm not suggesting you run around a parking lot in low 4WD doing figure 8's but driving in high on the road won't screw it up it will waste gas and ware tires. Think about this if Toyota tells you to drive it in 4 wheel drive they are the ones that have to fix it if it brakes under warranty for at least 36K and they aren't about to tell you to do some thing if it's going to cost them money. You drive your truck your way I'll drive mine the way I have for the last 49 years what's right for me is not necessarily right for you.
  5. Sep 18, 2011 at 5:12 PM
    #45
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Good luck with that. Sorry...maybe you missed this post.
    Quit being a stubborn ass. If you actually read all the posts you'll see exactly what I said and meant. Toyota tells you to drive in 4x4 yes. They also say in big letters NOT FOR HARD PAVEMENT. You want to try getting that warrantied, your ass is getting laughed out of the dealership. The lawyers are going to tell you that you should have found a soft terrain to drive in 4x4 on.
    But whatever. I feel sorry for your truck.
  6. Sep 19, 2011 at 9:04 AM
    #46
    DevL
    DevL Well-Known Member
    L
    And yet my post was 100% correct. Lockers used rockcrawling will break axle shafts at a greater rate than you will ruin transfer cases driving on the street in 4 hi. Should you leave a truck in 4hi on dry pavement? No. Will it cause cumulative damage? Yes... and so will using a locker while rockcrawling. I have seen dozens of snapped axle shafts from lockers and very few destroyed transfer cases. The winding and unwinding of the axle shafts when loaded will fatigue them. Yet we accept this wear. I accept the wear of using 4hi on pavement just like using my locker and it seems like I have a more realistic view of the risks and wear involved from the comments here. This 4hi on pavement issue is well known but less risky than you make it out to be. It woulb be great if I had a full time 4wd option, but I don't so I make due. If I bust the chain in my transfer case in 100000 miles I will just fix it.
  7. Sep 19, 2011 at 9:07 AM
    #47
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I'm picking up what you're putting down Hombrè.
  8. Sep 19, 2011 at 9:08 AM
    #48
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    ^^ This.
    ^^ And this.
    Don't worry about it man. A little driveline tension is no big deal. These things aren't delicate flowers.
  9. Sep 19, 2011 at 9:43 AM
    #49
    Manwithoutaplan
    ID
    :eek:
  10. Sep 19, 2011 at 10:07 AM
    #50
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That picture is crazy, how crappy that TC is to split in half. Unless TC was hit on the rock and cracked already.
    With so many people screaming here you would think our TC's are made out of paper or something.
    I think I need to buy FORD. :D My buddy went 100+ miles plus at highway speeds in 4wd. He did that several times, he tough 4wd is the same as AWD. ;)
  11. Sep 19, 2011 at 10:20 AM
    #51
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Nice post...ignore that Krazie guy :jerkoff: I agree...live and learn kids I drive 300 mile round trips in 4*4 all winter long..dry wet ice snow its my gas and tires but I'm safe
  12. Sep 19, 2011 at 10:40 AM
    #52
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Read your manual again there is nothing in it about not driving on hard pavement it says to drive it once a month in 4 wheel drive for 10 miles it does not say go out on a frozen lake or drive around in a sand pit. I do think you may have to deal with a lawyer if you drive around in your neighbors new mowed lawn " but officer I can't drive it on the street"
  13. Sep 19, 2011 at 10:56 AM
    #53
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
  14. Sep 19, 2011 at 7:02 PM
    #54
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    To the asshat who didn't leave their name with neg rep. Bite my dick.
    For Dry hard packed surfaces...use H2.
  15. Sep 19, 2011 at 10:42 PM
    #55
    SubFrozen
    SubFrozen r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    Toyota trucks are great. It's okay to drive in 4-hi, just don't swap between 4-hi and 2-hi at freeway speeds; slow below 65 (I go to 50) and switch. I constantly swap between the two on the freeway if I hit heavy rain or if I'm going through snow on long road trips.
    The clunk is okay, just tension. Happens to me at times, so I let off the gas and let it naturally slow a bit before switching.
    Dealership confirmed the above^^
  16. Sep 19, 2011 at 10:44 PM
    #56
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Oh , sorry about that
  17. Sep 19, 2011 at 11:22 PM
    #57
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    OZ-T just wants to bite your dick. :D
  18. Sep 19, 2011 at 11:24 PM
    #58
    OZ-T
    Peter North
    British Columbia
    OMG , I thought I sent that as a pm :eek:
  19. Sep 19, 2011 at 11:32 PM
    #59
    StandingCow
    NJ
    I am on to you... dirty canadian!
  20. Sep 20, 2011 at 5:15 AM
    #60
    twoodcc
    twoodcc Well-Known Member
    Alabama
    2008 TRD Offroad Prerunner
    What about driving in rain?
