boom boom bass on Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacosauro, Oct 5, 2024.
  1. Oct 5, 2024 at 10:56 AM
    Tacosauro
    Tacosauro [OP] Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Hey guys, I want to change OEM speakers to something with bass and quality sound.
    Anyone has done it? and any suggestions?
    Anything under 400$
  2. Oct 5, 2024 at 11:07 AM
    JeancoLunarTaco
    JeancoLunarTaco Well-Known Member
    FL
    22' Tacoma TRD-OR
    - Eibach Stage 2 Suspension (Front/Rear) 2.75" Lift - JBA UCA - SSW Dakar 17x9 -25 Wheels - Rays 57DR-X 17x8.5 et0 - Yokohama Geolandar 285/75 R17 Tires - CMC / Pinch Weld Mod - Prinsu Rack - Caliraised Light Bar - BajaDesign Fogs, Spots, Chase lights - Auxbeam 8Gang Switch Panel - C4 RR Front Bumper / CrossMember Delete - C4 HC Skid Plate - Badlands Apex Winch - Rock Sliders - R4T LCA Skid - OTT Tune (Spicy/Race) - Carven Custom Turndown Muffler - ECGS Needle Bearing - OEM / TRD-Pro / V2 Pro Grills - Custom Clear Tail Lights
    PRV speaker are a very good option they are about $300 for 4 6.5" depending the model. But if you want bass and good quality I suggest increasing the budget for a full audio set up imo. I changed only the speakers and wasn't that big of a difference, but when I upgraded to 8" speakers, new tweeters, 10" woofer, 2 amps it drastically changed the quality. volume is WAAAAAY higher and more controlled and quality is awesome.
  3. Oct 5, 2024 at 2:24 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    underseat 10" powered Sub under your seat, spliced into the rear speakers which are totally useless!
  4. Oct 6, 2024 at 6:31 AM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    I put in the infinity component system and it blows me away in quality of sound.
    https://www.amazon.com/Infinity-Reference-9630CX-Component-Speaker/dp/B07B8SDVKK
    In these tacomas make sure you properly seal the 6x9 speaker to the door frame for the best bass sound. The factory’s have foam already, I found using mounting tape the best for sealing them down. https://www.amazon.com/Double-Mount...ywords=3m+mounting+tape&qid=1728221281&sr=8-4
    Also for speaker mounting brackets, taco tunes has these really good heavy duty composite ones. I wouldn’t use the plastic ones if you’re looking to really use the bass in the doors.
    https://*********.com/shop/toyota-tacoma-audio-products/double-cab-audio-products/1-tacoma-double-cab-speakers-install-products/toyota-tacoma-6x9-heavy-duty-speaker-adapter-front-door-installation-kit/
    Adding an amp might help, but the crystal clear quality you get from the factory speakers is lacking. They’re made of paper and made really thin. Buy something that can handle the power from the head unit better like the component system from infinity. They put them stock in the high end cars for a reason.
    MGMDesertTaco likes this.
  5. Oct 6, 2024 at 6:51 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I spliced into the front channel. The stock head unit sends a very weak signal to the rear.
    Things that make big differences for cheap:
    Front components
    Mini amp
    Sound mat installed in doors
    Things that make moderate differences:
    Head Unit
    Subwoofer
    Things for chasing perfection:
    Sound mat installed everywhere else
    Rear speakers
    Get on crutchfield, look for components that have a reasonable frequency range (ideally one that can dig below 55Hz) and good sensitivity (better than 92dB usually means amp not required), start there.
    I'd personally recommend doing the front door speakers, a key amp, and sound-lining the doors at the same time. That can be done for sub 500 bucks easily enough. (I can't stress even a basic few squares' application of butyl mat enough - the more you reinforce the foundation, the cleaner the speakers can sing.)
    Add another 300 on top of that if you want an underseat that will buzz your bollocks.
  6. Oct 6, 2024 at 3:16 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Nothing wrong with that, but the Subwoofer actually only needs a low level signal, leaving my fronts to run my tweeters & front door speakers.
  7. Oct 6, 2024 at 3:36 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I suspect it all comes out in the wash after the gain knobs are dialed in. :cookiemonster:
    My setup has everything tapped into the front channel, then the door and sub amps go through their respective built-in line converters before sending on to speakers.
    Tocamo[QUOTED] and soundman98 like this.
  8. Oct 6, 2024 at 3:54 PM
    Sullivan0930
    Sullivan0930 Well-Known Member
    Daniel
    2024 TRD Offroad. iforce max. Bronze oxide.
    id suggest trying the plg n play beat sonic mini amp first. $300. Changing the speakers doesnt do much when the stock head unit doesnt put out much power to begin with.
  9. Oct 6, 2024 at 3:55 PM
    MGMDesertTaco
    Jesse H likes this.
  10. Oct 6, 2024 at 4:19 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    MGMDesertTaco[QUOTED] likes this.
  11. Oct 6, 2024 at 4:21 PM
    MGMDesertTaco
    I heard one after I bought the JL Stealthbox. It's got plenty of thump, more than you'd think for an 8". Had I known I probably would have bought it instead and saved the difference.
    Jesse H[QUOTED] likes this.
  12. Oct 7, 2024 at 2:43 PM
    Tacosauro
    roof rack
    I am getting truck back this weekend, and I will look around for audio from this comments
  13. Oct 8, 2024 at 6:08 AM
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Trd intake stuff More intake stuff Kdmax pro 10.0 yayayaya
    Ty
  14. Oct 12, 2024 at 5:31 PM
    Tacosauro
    roof rack
  15. Oct 12, 2024 at 5:35 PM
    BobsTaco91
    BobsTaco91 Active Member
    2017 TRD Off Road
    Tacosauro[OP] likes this.
  16. Oct 12, 2024 at 5:46 PM
    Tacosauro
    roof rack
    Dcubed69 likes this.
  17. Dec 3, 2024 at 9:15 PM
    lukeroe
    lukeroe Member
    2021 SR5 Trail Edition
    Tacophelia likes this.
  18. Dec 4, 2024 at 2:26 AM
    Tacophelia
    Tacophelia Well-Known Member
    Im not sure what stock system you have but i can tell you the base level speakers are thee absolute chintsiest speakers i have ever seen in my life. I think total weight of front+rear+dash was less than a pound combined. I was astonished by how chintzy they were. I guess in retrospect it probably is a modern miracle of engineering they sound as "good" as they did with build quality that was used. I do know they are only "stock" speakers....but i have pulled other stock speakers in the past as well from different vehicles so had an idea of what to expect.
    Just something to think about if you try to budget together an upgrade. It gets expensive to do it right but i couldnt see how even a budget pair of speakers mixed in with whatever amp/sub/head or no head unit you come up with would not sound better.
    EDIT: FYI....when i did it i just disconnected the rears since no one is back there and did a 2.1 active using components with mids in front door & tweeters in dash. Saved on the rears.
  19. Dec 4, 2024 at 2:47 AM
    Tacophelia
    Im not familiar with those key amps other than that i know people on TW use them. But the truck itself is not hard to tear down and work on yourself to route wires. I just used a typical 5 channel amp behind the driver side rear seat, sub on passenger side rear. Route wires thru the channels on the floor under doors to head unit and front doors\dash. Didnt bother with rears.
    The toughest part for me was getting replacement wires in the doors thru the boots as it is a pain. The rest was pretty simple just takes a little time. The factory speaker wires are miniscule but im sure you could use them if not pushing too much power. I believe you can tap into the factory wiring behind head unit if you wanted to re-use it and just get adapters for the speakers iirc.
    There are some good build threads on here that should give you ideas of difficulty and locations/options to use.
    EDIT: FYI....IIRC i believe there is some kind of roll off happening in the Entune factory happening as well. Something to think about if you are trying to add subs. I believe there are devices to try to correct this but honestly your better off pulling the head unit. See how it adds up :).
  20. Dec 4, 2024 at 7:00 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Its incredibly easy if you have ever spliced a wire. You split the front channels after HU output. One set goes to the key amp, the other goes to the powered sub/output converter.
    Run the key's auto-tune and set gains with the sub turned off. Then turn on the HPF on the key, set the sub gains to balance the amp.
