Boomer's Dashtop RAM (type ball) Mount- new stock available now!!!
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by oostroma, Feb 11, 2022.
  1. Feb 11, 2022 at 5:11 PM
    oostroma
    oostroma [OP] (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    The BDRM has 5 locations for mounting RAM type balls with 2 strategically placed slots for passing through USB power cables if desired. One thing I wanted to ensure was ease of installation and I think this is accomplished by spreading out the 5x fastening points along the entire length of the radio bezel. Also, I have concentrated on fit and finish by having the part CnC'd and then finished in a textured flat black powder coat which should keep any incoming light reflection to a minimum. When not in use I think it blends inconspicuously into the dash quite well.
    I have 1 pieces available for sale as of 06102024. The BDRM will come with required mounting hardware, E-mailed installation instructions, 4x plastic plugs for unused mounting holes and 1x ball mount.
    Cost is $125 US + 4% PayPal fee + shipping.
    Add surface mount USB as seen in picture: $20
    Add 1x additional ball mount: $10
  2. Feb 11, 2022 at 5:15 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Very cool piece.
    So, this attaches to the bezel. Is there any other attachment point or does this rely solely on the bezel for its support?
    Btw....what is that wired gizmo attached to the right end of the mount in the 2nd and 3rd pics?
    Mark77 and Skydvrr like this.
  3. Feb 11, 2022 at 5:19 PM
    oostroma
    Ontario
    Currently it relies on the bezel for support but because the mounting points are spread along the entire unit I think this improves stability.
    I will be developing an internal support bracket that will utilize the upper 2x radio fastening bolts as an accessory.
  4. Feb 11, 2022 at 5:27 PM
    oostroma
    Ontario
    I have 2x #4 mounting holes in the BDRM to install a surface mount dual USB jack.
    https://www.amazon.ca/gp/product/B07MXWQGDF/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  5. Feb 11, 2022 at 6:31 PM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    Very cool--nice job!
    oostroma[OP] likes this.
  6. Feb 11, 2022 at 6:50 PM
    camjamesj
    camjamesj Well-Known Member
    Cam
    ON, Canada
    ‘21 Cement OR DCSB
    Looks great!
  7. Feb 11, 2022 at 7:24 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    count me in- should I pm about purchase?
  8. Feb 11, 2022 at 7:38 PM
    oostroma
    Ontario
    Yes, send PM with full name and address so I can figure out shipping.
    MaverickT883[QUOTED] likes this.
  9. Feb 11, 2022 at 8:40 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    That's some really nice work right there
  10. Feb 11, 2022 at 8:42 PM
    OG_Tacoma
    Does this permanently leave holes in the factory bezel?
  11. Feb 11, 2022 at 8:58 PM
    oostroma
    Ontario
    Yes but why would someone remove it? It looks so good. Also, with nothing attached to it you can hardly tell it is there.
    Key-Rei and 818_Taco_4x4 like this.
  12. Feb 11, 2022 at 9:26 PM
    Windigo
    Farook
    '14 Acess Cab
    Put the letters TRD on that and sell millions
  13. Feb 12, 2022 at 2:14 AM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    So what is the difference between this and the other two that are on the market that are similar?
    Skydvrr and Absolut_Boost like this.
  14. Feb 12, 2022 at 2:27 AM
    oostroma
    Ontario
    I prefer to put my own moniker on the part I designed. Also, I believe @MESO had an issue with Toyota regarding the use of the TRD logo.
    BOMBS, DAMeehan, microsnook and 3 others like this.
  15. Feb 12, 2022 at 2:46 AM
    oostroma
    Ontario
    - I have designed the mount to fit along the entire length of the radio bezel providing 5 mounting points spread out with the one on the far right that can be used by the passenger.
    - it has a total of 5 fastening points which makes installation easier and takes considerably less time to complete than others
    - the notches for the USB cables are strategically places on the sides of the radio in case there was any liquid spilled on the dash it would not go directly onto the radio
    - the part is finished in a textured flat back powder coat which will reduce any reflection of incoming light
    - the part has 2x #4 mounting holes for installation of a surface mount USB jack
    - I provide 4x plastic plugs for the unused mounting holes
  16. Feb 12, 2022 at 4:08 AM
    oostroma
    Ontario
  17. Feb 12, 2022 at 6:01 AM
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    Do the fastening screws just thread into the plastic bezel or is there a nut or plate of some sort on the back side of the bezel?
    OG_Tacoma likes this.
  18. Feb 12, 2022 at 6:07 AM
    oostroma
    Ontario
    The 5x tapered fastening screws have a sizable washer and SS nylon nut to secure it to the bezel.
    Hardscrabble likes this.
  19. Feb 12, 2022 at 7:47 AM
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2016 Blazing Blue TRD Sport DCSB 4x4
    Like the design. Looks very functional.
  20. Feb 14, 2022 at 6:24 AM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Nice work!
    When do you expect to have the additional support bracket in production?
