Boost Gauge
Discussion in 'Performance and Tuning' started by apocataco2015, Jun 18, 2015.
  1. Jun 18, 2015 at 10:53 AM
    apocataco2015
    apocataco2015 [OP] Well-Known Member
    Clayton
    Salado, TX
    2017 Tacoma TRD OR 4x4
    Fox/OME/Icon lift. TRD Beadlocks. Toyo MT’s. Pelfreybilt, RCI, Mobtown armor.
    Can any recommend a good boost gauge to use with a supercharger? Please provide a pic of where you installed it. Thanks in advance!
  2. Jun 18, 2015 at 11:15 AM
    apocataco2015
    Clayton
    Salado, TX
    Thanks Rock. I know i'm going to sound like a newbie asking this question but what's up with the boost gauge reading both + and - PSI? I'm asking because my last vehicle with boost was a 96 eclipse gst and the boost gauge in that car started at 0 if i remember correctly. It was turbo charged and not supercharged of course so maybe there is something different with the supercharger with boost that i just don't understand. I'm shopping local dealerships to get the best price for the supercharger and fit kit installed. So far $6290 is the best price i have, but still waiting to hear back from 2 dealerships.
  3. Jun 18, 2015 at 1:17 PM
    apocataco2015
    Clayton
    Salado, TX
    Thank you Rock.
  4. Jun 19, 2015 at 10:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    "-" = inches Hg (Mercury) or Vacuum. Helps you determine if you have a vacuum leak. The needle will read closer to "0" on the engines when there is a vacuum leak at idle. From a starting point of around 19-21 inHg.
    apocataco2015[OP] likes this.
  5. Jun 19, 2015 at 11:10 AM
    apocataco2015
    Clayton
    Salado, TX
    Thank you Torspd. I guess I will go with one that reads the vacuum as well. Good call.
  6. Jun 19, 2015 at 11:13 AM
    apocataco2015
    Clayton
    Salado, TX
    Rock, would you recommend getting any other performance parts installed while the dealership is installing my supercharger? Pulley's?
  7. Jun 19, 2015 at 9:31 PM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
  8. Jun 25, 2015 at 1:52 AM
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
  9. Jun 25, 2015 at 4:22 AM
    apocataco2015
    Clayton
    Salado, TX
  10. Jun 25, 2015 at 4:35 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    I've been looking for some, too. Options are slim and seems many of the pillar mounts are the wrong color. I'd probably be better not knowing how little boost the SC makes with the crappy flash tune, it's pretty conservative and seems to dump more out the wastegate than in the intake. Still an improvement over stock though, I can actually pass people now without taking a mile of road.
    An engine runs in vacuum most of the time regardless the type of forced induction(turbo or supercharged) without heavy acceleration. even when you get up to speed you won't show much boost unless heavily modified
  11. Jun 25, 2015 at 4:52 AM
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    how much do you want for those two right there?
  12. Jun 25, 2015 at 12:59 PM
    6xchamps
    Fuquay Varina NC
    2015 AC
    Tried weaseling in there
    Denied
  13. Jun 25, 2015 at 3:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    http://www.tanabe-usa.com/vls.asp
    Very nice gauges, and can daisy chain the power between gauges. Effectively you only need to wire one it versus wiring them all in. Makes life simple.
  14. Jun 25, 2015 at 3:27 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't like the ricer logo's "Tanabe" that are written on the bottom. Otherwise those would be a very nice set of digital guages.
    How do you figure the analog ones CAN'T be daisy chained? They all require power to work anyways do they not?
  15. Jun 25, 2015 at 3:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Some gauges dont
    Some gauges don't come with the ability to add a power jumper wire between them.Mainly those which do, have a separate controller which is also necessary to run the gauges. That is why these are nice.
    No additional controller and have the power jumper ability, for ease of wiring.
    Tanabe is very high quality. From sensors to exhausts and other.
    12TRDTacoma[QUOTED] likes this.
  16. Jun 25, 2015 at 4:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No doubt they are a good company, but its that logo that kills a lot of my interest for them off. I haven't dealth with guages like that before, I just figured you were able to run the power to them all directly. I guess I was wrong about that.
  17. Jun 25, 2015 at 5:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just got to carefully look at the features of the gauges under consideration. Cheap gauges use large antiquated sensors. Expensive ones will use refined compact sensors.
  18. Jun 25, 2015 at 5:04 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Like a cricket in a gas chamber
    Biscuits and Torspd like this.
  19. Jun 25, 2015 at 5:22 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Twas the sole motivating force to build my engine. :anonymous:
  20. Jun 25, 2015 at 5:47 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Is how he buys condoms too
