Boost port???
Discussion in 'Performance and Tuning' started by JWP6114, Jul 14, 2013.
  1. Jul 14, 2013 at 7:22 PM
    JWP6114
    JWP6114 [OP] Well-Known Member
    Jake
    Newnan, GA
    2010 PreRunner SR5 supercharged
    TRD supercharger
    About to install the PLX boost module on a 2010 for a TRD blower. Can anyone suggest/inform what fitting do I need for the boost port and where exactly located on the aft side of the sc? A pic would be helpful.
    Also installing an A/F plx gauge as well. Any suggestion on where to mount these tow modules and where did you tap into switched power for the modules?
    Sorry so many questions in one post, the will show up Tuesday and I'm sure there will be some general instructions with them. Just looking for some specifics to get prepared for the instal.
  2. Jul 14, 2013 at 8:32 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    The boost reference port is the nipple with the orange vinyl cap near the cooler lines, top side close to rear of housing.
    I haven't had my nipple cap off yet, but it looks like a 1/4" fitting
  3. Jul 15, 2013 at 7:17 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    Seriously? I thought there was a brass plug on the back side, figured boost would blow off that plastic cap,
    If so, that makes installation a bit easier
  4. Jul 15, 2013 at 8:05 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Yup seriously. If you are hooking up a boost gauge you will hook your hose to that nipple on top with the orange cap on it.
  5. Jul 15, 2013 at 8:25 AM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Slide a 3/16" rubber hose on top of the fitting and you'll be fine, I've got a FPR (fuel pressure regulator) mod done but no boost gauge. Still had to use my boost port, with 9 psi that hose has not popped off whatsoever lol then it's as simple as a tee to connect the boost gauge in that line.
  6. Jul 15, 2013 at 9:16 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    can u explain the fpr mod? is it easy cheap? what are bennifits?
  7. Jul 15, 2013 at 9:25 AM
    2011supercoma
    2011supercoma Well-Known Member
    capt. schyler
    nola
    sr5 4x4, trd supercharged
    trd supercharger, afe cai, doug thorley lt hearders, magnaflow exhaust, rcd 4.5" lift with ome 883 springs, cbi ditch light mounts woth rigid industry D2 spot lights,
  8. Jul 15, 2013 at 9:28 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    I searched around a little and see some using aftermarket FPR's but not much talk on why, gain, or cost...
    def qurious of mod for exsisting FPR...
  9. Jul 15, 2013 at 11:27 AM
    ToyotaTacoma4Ever
    Eric
    Alberta
    The simplest way of explaining without gettin into to much details is that the purpose for the FPR is to increase the capacity of your injectors. The way it does this is that the regulator makes fuel pressure and boost pressure a 1:1 ratio with the boost from your supercharger. So with every psi that's coming out of the supercharger will raise the fuel pressure by that much.
    So im running roughly 9psi of boost with the 2.7 pulley. Static fuel pressure is 43.5psi. With the FPR Mod the 9psi of boost will raise fuel pressure to 52.5psi when your in boost for you don't max out your injectors duty cycle at high RPM's
    Making sense? lol
    Very easy to install and you can get one for about $150 after getting some hoses and fittings maybe $200?
    I've got a whole write up in my build thread about it
  10. Jul 15, 2013 at 1:21 PM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    Can the oem fpr be modified?
  11. Jul 15, 2013 at 2:03 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Not that I know of, easier buying an adjustable aftermarket one with a bigger diaphragm than OEM since OEM is set for one specific pressure
    but you will have to put your boost line to the OEM fuel regulator when you install your boost gauge, heard it helps a bit with injectors but I'm not 100% sure on the OEM one
  12. Jul 15, 2013 at 7:07 PM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    Roger all. Thanks
  13. Jul 15, 2013 at 9:26 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Here's one spot where you can put your gauges, there called flex pods, you can get them from URD
    http://urdusa.com/Electronics-Wideband/Gauges-Gauge-Mounting-Solutions/c66_77_177/index.html
    OR you can go with the pillar style on the side of where the handle is
  14. Jul 16, 2013 at 2:03 PM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    question... are the upsream o2 sensors AFR sensors and the downstream o2 sensors narrow band? got my plx gauges in and dont know where to put the new sensor.
    caled PLX and they said if you can replace a narrow band one and run the grey wire to the ECM to trick the computer into functioning normally.
    Called gadget at URD racing and he said you cant do that, you have to buy bung and cut a hole and weld in the new sensor... (weak sauce)
    where do i put this damn new o2 sensor? and any info on installing the grey wire to ECM would be helpfull too.
  15. Jul 16, 2013 at 2:17 PM
    Brunes
    Brunes abides.
    Rotorhead
    I'm sure you could input the wifeband signal into the ECM...but if you use an existing bung for the wideband sensor, you will only be reading one bank of the engine. All the advice I got was to put the bund into the collector in the y pipe to read all the exhaust, not just one of the two banks.
  16. Jul 16, 2013 at 2:36 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Simplest way is to simply install an extra bung in the y-pipe collector IF you have a straight through exhaust
    If you still have your cats then I dunno if that will affect the sensor after the cats so you might be stuck reading one bank by putting the sensor before the cats
  17. Jul 16, 2013 at 2:49 PM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    Where can I find a wiring diagram or the ECM?
  18. Jul 17, 2013 at 10:47 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    Anyone?
  19. Jul 17, 2013 at 3:56 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    U has PM
  20. Jul 18, 2013 at 10:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
