boostedka's Turbo 3RZ Tacoma
Discussion in '1st Gen. Builds (1995-2004)' started by boostedka, Jun 3, 2016.
  1. Feb 2, 2018 at 5:36 PM
    #421
    ak97taco
    ak97taco Well-Known Member
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Exterior 2.5" leveling kit Rocktrix 17" wheels 285/65/17 Yokohama Geolandar's Leer shell Diode Dynamic fogs Morimoto XB Amber headlights Alpharex taillights Body Armor Hiline bumper Prinsu roof rack TRD Pro Grille Caliraised LED 42" amber light bar 2 - bumper light bars and 2 pods behind grille Overland Equipped aux power tray Meso Customs puddle pods with switch Interior LED light kit Meso Customs stealth pro shift knob Oostroma dual latching relay for shift knob Clazzio leather seat covers Clazzio seat warmers Quick charge USBs Dual, amber & white lightbar switch from Cali Raised N2 Designs remote start with app Meso customs interior black out kit AJT Designs interior black out kit Taco Garage DSM phone mount
    Thanks! Okay yeah I just got a big assortment, I’m sure somethings gotta match
    boostedka[OP] likes this.
  2. Feb 2, 2018 at 5:37 PM
    #422
    boostedka
    boostedka [OP] Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Nice. Good luck!
  3. Apr 19, 2018 at 9:03 AM
    #423
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Ever know how much power you were putting down when you were on stock ECU?
  4. Apr 19, 2018 at 9:16 AM
    #424
    boostedka
    James
    NM
    This dyno sheet was on stock ecu with pink top injectors with an 8psi spring in the WG.
    182hp/220tq uncorrected at 5000ft elevation.
    226hp/273tq corrected for sea level.
    jgill21[QUOTED] likes this.
  5. Apr 19, 2018 at 9:18 AM
    #425
    jgill21
    Jake
    Nashville
    Ever time a 0-60 or anything like that? I want boost badly and should be able to afford it after this summer
  6. Apr 19, 2018 at 1:18 PM
    #426
    boostedka
    James
    NM
    I haven't. I don't really like to launch it hard on pavement with heavy offroad tires.
    The power increase was definitely significant. I would estimate I gained about 75-80hp at the wheels.
    Jcyr and jgill21[QUOTED] like this.
  7. Apr 19, 2018 at 2:01 PM
    #427
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    You will still get beat off the line by a v6 camry without putting time into the block BUT.... it’ll have way more pep and make merging from 30-70 on a highway more fun ect. If you’re looking for blazing speed off the line be ready to drop some coin....
  8. Apr 19, 2018 at 2:03 PM
    #428
    Jcyr
    Jack
    North east
    Pretty cool dyno chart tho!! How much did that session cost you
  9. Apr 19, 2018 at 5:02 PM
    #429
    boostedka
    James
    NM
    $40. It was a dyno day at a local shop. $50 for 3 pulls. I just did 2 since it was leaning out on the top end so he knocked off $10. I think it’s normally $75 per hour. Pretty reasonable.
    MadTaco461 and Jcyr[QUOTED] like this.
  10. May 7, 2018 at 3:27 PM
    #430
    jgill21
    Jake
    Nashville
    I live in this thread now. What did you do with the vac line for the FPR?
  11. May 7, 2018 at 7:36 PM
    #431
    boostedka
    James
    NM
    Initially, I hooked it up to one of those ports on top of the Throttle Body. This way it sees boost and little to no vacuum. Later on when I ran the 440's I hooked it up to the Intake Manifold so that the vacuum it sees there would help to trim the fuel at idle, but it would still see boost as well to increase fuel under load.
  12. May 8, 2018 at 3:13 PM
    #432
    jgill21
    Jake
    Nashville
    Gotcha. I'm looking to ditch that metal resonator on the intake pipe but wasnt sure where I could hook that line up to. Thanks!
    boostedka[QUOTED][OP] likes this.
  13. May 8, 2018 at 4:37 PM
    #433
    boostedka
    James
    NM
    You should be good connecting it to anything on the intake manifold. Even T-ing into an existing line works too. You can also replace that little plug on the front of the intake manifold with a brass nipple and connect it there as well.
  14. May 8, 2018 at 8:11 PM
    #434
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Wait, I thought you don't want it on that plug because it'll see vacuum and there's no reason for it to see anything but atmosphere.
  15. May 8, 2018 at 8:18 PM
    #435
    boostedka
    James
    NM
    Wouldn’t it read vac from the intake tube as well since an engine is just a hit he vacuum? I ran a 5vz I used to have that way with any issues
  16. May 8, 2018 at 8:19 PM
    #436
    Speedytech7
    Should be much lesser if any before the throttle plate I'd think, only having the throttle open a lot would do it.
  17. May 8, 2018 at 8:53 PM
    #437
    boostedka
    James
    NM
    It’d be interesting to hook up a boost gauge to both places and see what kind of readings each gets.
  18. May 14, 2018 at 5:02 PM
    #438
    boostedka
    James
    NM
    Truck is officially back to stock and sold
    MadTaco461 likes this.
  19. May 14, 2018 at 5:10 PM
    #439
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    WOW !! I didn’t expect that but i get it with all the hassle. You must have kept all the stock stuff.
    Running Board Man likes this.
  20. May 14, 2018 at 5:14 PM
    #440
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    What's the replacement?
    Jstand likes this.
