Boot Slide mod. No more blowing cv boots.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 802YOTA, Mar 16, 2011.
  1. Aug 17, 2011 at 1:07 PM
    DAMNDUKE
    DAMNDUKE Member
    Duke
    albany ny
    2002 sr5 tacoma
    2.5" spacer lift, K&N intake.
    So you used the old boot and clamped it down. But did you take your cvs apart to put the old boot on? I have 2 brand new Cv shafts that I'm putting in my truck and the boots are already assembled. I was going to unclamp the new boots slide them down, cut what I need from the old one, then make another cut so I can just POP it over the shaft and clamp it. I don't think there should be any problem with doing it that way.
  2. Aug 17, 2011 at 1:47 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    take your new cv axles and trash the clips on the upper boot on the lower portion of the boot. (confusing sorry).... you have your upper boot with 2 clamps and your lower boot with 2 clamps...take the smaller "shaft clamp" off the upper boot on the cv axle slide it ("it" being the boot) down the shaft till you think your fins have a large enough gap between each other then tighten the shit out of it with a hose clamp inplace of the original upper boot lower clamp spot.... (again if that makes any sence)....this is what i did and it has worked great.
  3. Aug 17, 2011 at 1:57 PM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    nah forget them just put that wagoneer axle under it
  4. Aug 17, 2011 at 3:21 PM
    DAMNDUKE
    DAMNDUKE Member
    Duke
    albany ny
    2002 sr5 tacoma
    i see what your saying. would a regular hose clamp like this work?
    http://www.google.com/products/cata...&sa=X&ei=fD5MTqLDJIzrgQfvyI1z&ved=0CGwQ8gIwAw#
    or is there something more heavy duty needed?
  5. Aug 19, 2011 at 8:59 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  6. Aug 28, 2011 at 8:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I need to do this. My fins are rubbing bad...but i am still lost on what to do exactly...
  7. Aug 29, 2011 at 12:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :thumbsup: cool I think ill do that then asap. What size should I get of you know...
  8. Aug 29, 2011 at 1:33 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    sub'd. lift going on soon.
  9. Sep 11, 2011 at 12:28 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    I did the mod today on the inner boots, works well and fins are not touching anymore.
    Like somebody else in this thread mentioned earlier, how about the outer boots? Shouldn't those be done as well?
  10. Sep 11, 2011 at 12:33 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    thats the thing i was wondering about. will this method eventually allow the clamp to slip back down the axle?
  11. Sep 11, 2011 at 12:34 PM
    NetMonkey
    Geogetown, TX
    i have a 3" lift and the fins on the outter boots are not touching. its just the inners.
  12. Sep 11, 2011 at 2:16 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    So essentially you don't need an extra boot or anything to do this. Just get some hose clamps, take off the old clamp, stretch the boot out further and reclamp it down? Sorry I'm not really following haha
    Taco2222 likes this.
  13. Sep 11, 2011 at 2:33 PM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    Alright, Thanks! Going to try this tonight. I've changed out 3 sets of cv's within the past year. Hopefully this will work for for me.
  14. Sep 11, 2011 at 2:45 PM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    Yep same setup haha. Yeah the boots just keep tearing, the 3rd time it wasn't because of the lift though. Toyota tore it when my dad took it into the dealership for maintenance while I was out of state, and they wouldn't own up to it. Proved to me why I don't let anyone work on my truck but myself...
  15. Sep 12, 2011 at 7:22 AM
    #35
    NetMonkey
    Geogetown, TX
    just making sure that i understand this correctly... should the rtv sealant be applied to where the axle/boot meets or where the boot/clamp meets?
    EDIT:
    http://www.permatex.com/products/au...matex_Hi-Temp_RTV_Silicone_Gasket_Sealant.htm
    hmm... so the description sounds like the sealant should be applied to where the axle/boot meet. :)
  16. Sep 12, 2011 at 10:21 AM
    #36
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    Yes, apply to shaft then slide boot over it. Clean the shaft first.
  17. Sep 12, 2011 at 5:21 PM
    #37
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    ... :rolleyes:
  18. Sep 13, 2011 at 6:41 AM
    #38
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    your putting gasket sealer on your boots? is it leaking? someone needs to learn how to turn a wrench harder.
    "Not recommended for use with cut rubber gaskets" so it could work...or you could make a mess.
  19. Sep 13, 2011 at 6:51 AM
    #39
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
  20. Sep 13, 2011 at 10:34 AM
    #40
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Kinky operation.
    Sealant helps to make a bond. Only so tight you want to make the clamps before they start to cut into the boot.
